BIKELAND > FORUMS > ZX12R ZONE.com > Thread: my latest turbo street ZX-12R updates NEW TOPIC NEW POLL POST REPLY
posted April 26, 2019 02:05 PM
To make a long story short, i found the limits of stock pistons with a turbo system, and then upgraded everything.
https://drive.google.com/file/d/1Zs_6Pza5xMvFYVvosqHfJGw0eCAXGukH/view
posted April 27, 2019 04:20 AM
Pix no workee!
posted April 28, 2019 02:59 AM
they are working on my end, just too big?
posted April 28, 2019 07:09 AM        Edited By: KZScott on 28 Apr 2019 14:19
[img] [size=600] https://www.kawasakiworld.com/attachments/zx-12r/14796d1552276060-skips-resurrection-build-thread-20190303_151716_1552276004831.jpg[/img]
test
posted April 29, 2019 08:58 AM
They aren't displaying. I believe Kawasakiworld may have external linking blocked. I'll see what freek says maybe he knows why.
posted April 30, 2019 09:19 AM
all the pics work on my end with the exception of the one that i attempted to resize from memory. i dont have the code, and cant quote a post from yrs ago to find it
frEEk
posted April 30, 2019 01:59 PM
Yeah they don't let you hotlink the images. Either you can see it because you have them cached already or maybe just because you are logged into that board.
posted May 01, 2019 10:58 AM
Wanna zap this thread and I'll do a new one?
posted May 18, 2019 12:31 AM
i guess not...
added some oil capacity
had a head o ringed and then i ported it
the intake didnt need as much work
This bit was a lot of work
(pressure testing)
the core kinda gets in the way of mounting a damper with the conventional bolt and nut method, threaded bosses work great
sharp ended sanded down some and polished
new header
angled inlet
just fits with the large diameter, stubby wix filter
no filter poking out
intercooler heat exchanger clearance (tight fit!)
its all stock I swear! just a slip on can, doesnt even have a power commander :P wanna race?
spring and a second small stage of boost on a button for special occasions. sae and std correction factor. this is on pump gas and the 300+ pull averages about 12 psi. stayed conservative for a change and stopped turning it up there.
stealth mode!
https://drive.google.com/open?id=1Zs_6Pza5xMvFYVvosqHfJGw0eCAXGukH
posted May 19, 2019 12:26 PM        Edited By: fish_antlers on 19 May 2019 19:27
Right on!!! Now we are talking!!
RobertMcBeth
posted May 21, 2019 08:25 AM
Madness!!!! Madnesss I Tell Ya
This build is crazy Mr. Scott
It’s better than pornhub
posted June 17, 2019 01:19 PM
been out a few times now, finally got insurance last week. have just been on the "low power" setting so far and im quite happy with it. its a little on the rich side at cruise so going to throw it back on the dyno and tweak the vac tables slightly and try and get a little better fuel economy... all stuff under 10%tps. its an animal at 7k. power wheelies on command with the land speed gearing in 2nd.
Bigbore4
posted August 07, 2020 07:16 PM
Nice welding
Quick Reply:
Copyright 2000-2022 Bikeland Media
0.52245807647705 seconds processing time
