BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 2008 ZX10R Specs NEW TOPIC NEW POLL POST REPLY
YZF
posted December 03, 2007 05:43 AM
2008 ZX10R Specs
Model Year 2008
Engine type Liquid-cooled, 4-stroke In-Line Four
Displacement 998 cm³
Bore x stroke 76.0 x 55.0 mm
Compression ratio 12.9:1
Valve/Induction system DOHC, 16 valves
Maximum power 138.3 kW {188 PS} / 12,500 rpm
Maximum power with RAM Air 147.1 kW {200 PS} / 12,500 rpm
Maximum torque 113 N•m {11.5 kgf•m} / 8,700 rpm
Fuel system Fuel injection: ø43 mm x 4 (Keihin) with oval sub-throttles, dual injection
Ignition Digital
Starting Electric
Lubrication Forced lubrication, wet sump with oil cooler
Transmission 6-speed, return
Final Drive Sealed chain
Primary reduction ratio 1.611 (87/54)
Gear ratios: 1st 2.600 (39/15)
Gear ratios: 2nd 2.053 (39/19)
Gear ratios: 3rd 1.737 (33/19)
Gear ratios: 4th 1.550 (31/20)
Gear ratios: 5th 1.400 (28/20)
Gear ratios: 6th 1.304 (30/23)
Final reduction ratio 2.412 (41/17)
Clutch Wet multi-disc, manual
Frame type Backbone/Twin-tube, aluminium (Pressed/die-cast composite structure)
Rake/Trail 25.5° / 110 mm
Suspension, front 43 mm inverted fork with DLC coating,rebound and compression damping, spring preload adjustability and top-out springs
Suspension, rear Bottom-Link Uni-Trak with gas-charged shock and top-out spring. Stepless, dual-range (high/low-speed) Compression damping. Stepless Rebound damping. Fully adjustable Spring preload
Wheel travel, front 120 mm
Wheel travel, rear 125 mm
Tyre, front 120/70ZR17M/C (58W)
Tyre, rear 190/55ZR17M/C (75W)
Brakes, front Dual semi-floating 310 mm petal discs, 10-button aluminium rotor carrier Dual radial-mount, opposed 4-(aluminium) piston
Brakes, rear Single 220 mm petal disc Single-bore pin-slide, aluminium piston
Steering angle, left / right 27° / 27°
Dimensions (L x W x H) 2,110 mm x 710 mm x 1,135 mm
Wheelbase 1,415 mm
Ground Clearance 125 mm
Seat height 830 mm
Fuel capacity 17 litres
Dry weight 179 kg
Complies to EU emission limit EURO 3
ricksgsxr
posted December 03, 2007 09:18 AM
Finally released thanks
A little heavier than I would of thought at 394lbs dry
NinjaNick
'08 ZX14 (Blue)
posted December 03, 2007 06:21 PM
Horse power (hp): kW x 1.341 = hp
Nm / 1.35491= tq/ft lbs
83.4 ft lbs torque
185.46 Horsepower
YZF
posted December 04, 2007 03:27 AM        Edited By: YZF on 4 Dec 2007 03:32
horsepower, metric (mhp) = KW * 1.36
So thats 188hp standing still and 200hp riding.
zxhoya
posted December 04, 2007 10:30 AM        Edited By: zxhoya on 4 Dec 2007 10:33
I see no mention of a slipper clutch?
Could someone list the dry weights of the previous gen. ZX-10R's.
''The angle of my dangle is inversely proportional to the heat of my meat'' Will Ferrell
posted December 04, 2007 01:35 PM
I pointed that out too, but in another thread they enlighted me
NinjaNick
'08 ZX14 (Blue)
posted December 04, 2007 03:51 PM        Edited By: NinjaNick on 4 Dec 2007 17:07
83.4 ft lbs torque
185.46 Horsepower
1 kilowatt = 1.34102209 HP
185.46 HP = 138.2974 Kw
yelozx10r
Green '07 zx6r
posted December 04, 2007 11:53 PM
Yeah and 197.26 hp with the ram air
Goodness me!!!
By the time you read this, I'll be gone!
YZF
posted December 05, 2007 01:50 AM        Edited By: YZF on 5 Dec 2007 01:51
83.4 ft lbs torque
185.46 Horsepower
1 KWatt = 1.35962 Metric HP!
So 147.1kW = 200 Metric HP. Here, in Europe, we use normal figures.
http://www.convert-me.com/en/convert/units/power/power.kilowatt.en.html
You think KHI official figures are wrong? No they are not
NinjaNick
'08 ZX14 (Blue)
posted December 05, 2007 09:58 AM
No way! USA uses normal figures! lol
posted December 05, 2007 11:18 AM
Normally I would agree that normally none of you are normal.. LOL
posted December 05, 2007 02:53 PM
Goodness me!!!
ya ya big numbers. andlets think about this, peak HP doesn't win races, the torque on the way to peak HP does.
and by the way is that true rear wheel HP, or BS horsepower at the "crank" :P
YZF
posted December 06, 2007 12:20 AM
This is crank HP ofcourse ( 08 CBR1K has 178 crank HP).
Rear wheel HP reported (unofficially yet) from Akrapovic - 175 , with Akrapovic full exhaust - 185rwhp.
This is monster.
yelozx10r
Green '07 zx6r
posted December 06, 2007 01:59 AM
boy that is alot of rear wheel hp... and yet the comments about the '08's agility keeps coming to mind.
Lots of power and agile!!! "bleeding fast"
There's just no denying the 10.
So the CBR has less HP than the 06/07 10 had... but I'm sure it will handle nicely. :P Its power will have a wide band of torque I'm sure and it will be very pleasant to ride on the street.
The 10 eats children for breakfast and is a beast!!!! If you want a superbike that just ooses inherent anger then the 10 is for you. If you like a sensible bike then the blade is for you.
Peak HP will leave the CBR with the 600's on the straight :P Can you say that the CBR is going to handle better? Can you say that the 10 won't be able to put that monster power down?
The CBR 600 has a great amount of torque over the zx6... does that make the 6 slower... not a chance!!!! Does it make the 6 terrible to ride in traffic... no! Does the CBR600 leave the zx6 behind when riding together... nope!!!
So where is the competition here? Each bike suits a market.
I personally buy bikes according to how they make me feel. I currently ride an 07 zx6r and that friggen hyperactive engine makes me feel awesome! Keep the revs up and lean, thats what its all about.
Sensible aint for me!
posted December 06, 2007 08:07 AM
ZX10 has always been ahead in "peak horsepower", thats no secret.
Thats not where winnings take place regarding checkered flags at road races, or the best handling bikes on the streets.
And the Kawasaki ZX6R was nowhere near the hottest bike for '07 in its class, for street or for track although yes its always been a great bike!
0.22773194313049 seconds processing time
