posted April 25, 2002 07:08 AM
ZRX 12 questions
Jamie,
Although the engine "architecture" is similar and many aprts interchange, the crank, cases, cylinder, and cams certainly do not, since the cam chain is moved about 3mm to the left.
Also, the gear pitch on the primary drive (crank/clutch) is different on both the ZRX 11 & 12 and the ZX-11. You can swap the cranks between the 11's as long as you also swap the clutches.
Basically though, a ZRX 11 or 12 should bolt into any place a ZX-11 was previously installed.
BTW, We have NEW ZRX 1200 "crate" motors for $4995.
Doug
