BIKELAND > FORUMS > BIKE CHAT > Thread: 1982 suzuki gs850l please help yall NEW TOPIC NEW POLL POST REPLY
Big country
posted August 08, 2014 11:58 AM
Bike has 2 dead cylinders, changed coils and plugs, it does have fire to the plugs, tested it with a plug tester light, also removed it and verified that it sparked, but 2 head pipes still cold, before the coil swap it was numbers 1&3 now its numbers 3&4 one cylinder from each side of the 2 coils . Never had such a wierd problem before... How can i fix this..carbs are synced and apped to be working correctly, the cylinder just floods and wont ignite.... Also on the compression check all cylinders are 120lb... Thanks for any info on what to try yall
2001 zx12r custom paint,
stretched, 16,50,
runs 5.80's 1/8th mile @117mph
sagot
posted January 30, 2015 07:23 AM
Sounds like the leads from the coils... or the caps. I can't remember if they are fixed (glued in) but I have cut them out before and there is a sharp pin inside the coil that you can shove a generic HT wire into...?
Blank
sagot
posted January 30, 2015 07:26 AM
Also. Sometimes spark is weaker under pressure, than as in a spark test outside the cylinder!
Blank
0.28137898445129 seconds processing time
