BIKELAND > FORUMS > ZX-14.com > Thread: Gear Indicator NEW TOPIC NEW POLL POST REPLY
zx14c5
posted September 09, 2008 06:11 AM
Gear Indicator
Based upon other message threads, I know that when switching to a 16/43 gear on a ’08 ZX-14, I will likely have problems with the gear indicator displaying incorrectly especially in 4/5/6, because of how the ECU computes the selected gear as opposed to having an actual gear selection sensor.
Does anyone know if this is true for a 16/42 setup? Would this combination be right on the edge but will the ECU gear indicator still work properly in most cases? I'm not overly concerned with losing the indicator functionality, just curious where the edge is.
posted September 09, 2008 06:44 AM
i run - 8% on the speedo healer with stock gears to get an accurate speedo and that meeses with the upper gear indications, so yes a 16/42 would probably do the same
zx14c5
posted September 09, 2008 01:09 PM
If you have the upper gear indication problem with stock gearing (17/41) when the speedo is modified -8% by the speedohealer, then I should be able to correct the upper gear indication problem when using 16/43 by also installing the speedhealer and modifying the indicated speed appropriately. Am I missing something here?
Thanks.
gilberjj
Friend of Fast
posted September 10, 2008 07:45 AM
sorry for the thread jack, but my gear indicator is delayed by several seconds at times, and sometimes it displays the wrong gear and then figures itself out..... very annoying
posted September 10, 2008 12:50 PM
don't watch it too much you will wreck
posted September 10, 2008 01:04 PM
Thanks.
your bike uses an optical sensor output from your counter sprocket combined with a math formula to derive speed and gear indications. the speedo healer intercepts that signal and adjusts it higher or lower to give you the correct speed when you make gearing changes. any change from the stock formula will cause irregularities in the gear indication.
zx14c5
posted September 11, 2008 06:17 AM
OK, Thanks bigdtd.
shane661
posted September 11, 2008 06:23 AM
So, if you change factory gearing there is no way to make the gear indicator reliable?
pazx14rider
posted September 13, 2008 11:27 AM
if you pull your flies the indicator is screwed anyhow!
Copyright 2000-2022 Bikeland Media
0.33745718002319 seconds processing time
