BIKELAND > FORUMS > ZX-14.com > Thread: stutter NEW TOPIC NEW POLL POST REPLY
Bigbluebeast
posted March 27, 2012 09:51 AM
stutter
I took off the secondary throttle bodies on my 2007 ZX-14, she starts and warms up fine, but once I get moving anything below 3k rpm and she stutters, I don't see the tach move, and once above 3k she maintains speed fine, but still stuttering, but not nearly as bad, I figure a power commander will fix it, I still have no mods done, even though I have 52k miles, Don't hate, but any ideas on what would fix it will help.
Bigbluebeast
posted March 27, 2012 10:08 AM
I didn't mean to put that emoticon on there, I accidentally hit it.
Bigbluebeast
posted March 27, 2012 11:58 AM
Nobody has any clue what it might be?.
BLK ICE
posted March 27, 2012 12:03 PM
try a PC with no-flies map.
ground the PC to the frame, not under the coolant tank.
posted March 27, 2012 12:04 PM
I have pulled the flys on a ton of zx14s and never had any stuttering even with no P/C or mapping .. Go back and check your work , you may have left something undone or unhooked ..
dakota9498
posted March 27, 2012 12:06 PM
Check the ground on the PC.
2008 ZX14
posted March 27, 2012 12:08 PM
He can't check what he doesn't have ..
dakota9498
posted March 27, 2012 12:09 PM
Doh....lol, didn't see that.
2008 ZX14
shawnski
posted March 27, 2012 12:12 PM
Did u count all the screws to the plates make sure one was not dropped in there.
posted March 27, 2012 12:30 PM
lol .. i didn't at first either ..
BLK ICE
posted March 27, 2012 12:33 PM
I did.
kawa74
posted March 27, 2012 12:40 PM
Vaccum line off, Vaccum leak around TB's , check TB's for Sync, all blades moving in Sync,
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
blackbullet76
posted March 27, 2012 03:14 PM
What about a bent secondary butterfly shaft? Could that cause it?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Bigbluebeast
posted March 27, 2012 06:08 PM
I counted, the screws all were there, when she idles, it's kind of jumpy, I'm beginning to think it's one of the ignition coils.
shawnski
posted March 27, 2012 10:03 PM        Edited By: shawnski on 28 Mar 2012 13:17
I had all my 3 previous ZX14 done and no problem... And if you did not have that problem before the changes, then must be some vacume leak or bad connection...
Remember bike is 5 years old and a lot of miles... Any thing can be unplugged and plugged back in and be no good..
posted March 27, 2012 11:12 PM
yes...... ask me how i know .... .......
Bigbluebeast
posted March 27, 2012 11:16 PM
That's true, could be the problem, She has to go in for her 4th valve ajustment, maybe they'll find the problem, or it'll fix it, we'll see.
MJ
posted March 28, 2012 12:13 PM
I pulled my flies on my bike bone stock, and helped others, and have never seen a stuttering problem. Just a boatload more low end. Something else must have happened when you pulled your flies.
Newf14
2007 ZX1400
posted March 29, 2012 02:09 AM
Mine dose almost the exact same thing, I had slipons and a PCIII and the bike was fine,I than pulled the flies bike was still fine.(PCIII grounded to the coolant bottle bolt and battery post on frame One winter I added a Brocks exhaust and a speedo healer, thats when it started to happen to me. I find it happens to my bike when your goin slow in the lower gears below 3k rpm , but mind dosent do it all that much just evern now and than after that she is fine... I know it isnt the exhaust or maps cause everyone has them and it would be experienced in more bikes, I am thinkin it may be the speedo healer....who knows I never did unplug it to see....
Newf14
Big Earl pearl
Get rich to this
posted March 29, 2012 04:43 AM
Nope clean tank or put some type of cleaner in it like sea foam. I have a 07 that did this! Dirty filter inside fuel pump!
kawa74
posted March 29, 2012 05:51 AM
ASK ..Smokin..., he done been there, done that, .... BENT sub- throttle shaft...., not rotating Sticking or Stuck ,
Sub-Throttle Senser not sending correct signal to ECU
Copyright 2000-2022 Bikeland Media
0.77971720695496 seconds processing time
