Blkhulk14
posted November 09, 2013 04:47 AM
Ecu flashing
I have an 08 zx14, I sent my ecu to get flashed. Well when he begun to flash it he found out it was an 06 ecu and it caused a problem when trying to rewrite. So he is waiting to hear back from his software guy. Now can the ecu be flashed with an 08 bin or would I need another ecu. Thanks in advance
Romans
posted November 09, 2013 12:26 PM
If you have the software for both ECU's it is easy to copy one over the top of the other. Not sure why you were running 06 ECU in a 2008 as the fuel requirements are different. Are you sure the motor is not a 06 or 07 ?
On the top o the ECU there is a 9 digit model #. Post it for me and I will confirm your findings.
Blkhulk14
posted November 09, 2013 07:18 PM
I don't know either. I don't have the ecu back yet. I will look today on the motor to see what I can find though. My title and frame says 08. I guest that explain Why 08 powercommander maps can't be directly downloaded to the bike.
Blkhulk14
posted November 09, 2013 07:27 PM
This is the number to the piggyback for the ecu.92161-0288
Blkhulk14
posted November 09, 2013 08:39 PM
Nevermind that's the ecu holder number
Romans
posted November 09, 2013 09:46 PM
Edited By: Romans on 10 Nov 2013 13:48
2006 2007---------- 2008-2011
21175-0084-------21175-0142
21175-0089-------21175-0154
21175-0090-------21175-0156
21175-0101------- And so on.
If you get stuck, I will flash ECU over to whatever you want. You just pay for shipping.
But First
The injectors are a different colors from 2006,07 to 2008,11 confirm your color. Maybe some here can tell you which is the 430cc color compared to 340cc color. I can't remember.
This will help confirm your engine model year or at the very least which injectors are being used.
Blkhulk14
posted November 10, 2013 01:17 AM
It looks like there blue. And aren't the fuel pump on the 08 flat, well low profile?
Blkhulk14
posted November 10, 2013 03:01 AM
Ok looks like my injectors are 06-07. How can u see what year the motor is zxt40ae002837?
Romans
posted November 10, 2013 07:30 AM
ECU 06-07 injectors 06 -07. Sounds like you have all the info you need.
Blkhulk14
posted November 10, 2013 08:05 AM
Thanks, I been doing some digging around. Now I wonder if the engine is the same year.
