ronaldnnn
posted January 04, 2017 08:18 PM
O2 Sensor question on 2016 model...
I called up Dynojet about a PC V for my 2016 ZX14r and was told none was or will be available because of an issue with the bike having an O2 sensor...
Well, I have looked as much as I could see and don't see any sensor on the header pipes or exhaust, anybody got a clue as to what or where there is one?
Or is it possible the guy at Dynojet is just wrong and there is none?
Ron...
ronaldnnn
posted February 20, 2017 08:29 AM
Just found the O2 sensor, somewhat hidden on lower left side of mid pipe..now my question is this...with an after market pipes installed will the O2 sensor send proper signal to ecu and adjust fuel/air mixture to optimum mixture.
Also, has anyone installed front lowering pegs on a 12-17 model, if so..what kind, cost and where to get them..
Thanks,
Ron
Ron...
ronaldnnn
posted February 20, 2017 08:30 AM
Edited By: ronaldnnn on 20 Feb 2017 16:30
opps...I mean lower right side of mid pipe for O2 sensor...
Ron...
bfg9000
posted March 01, 2017 06:18 PM
Edited By: bfg9000 on 2 Mar 2017 02:19
My bike is a 2013 SouthEast Asia model ZX-14R which is very similar to the Euro/Australia model which has an O2 sensor.
The O2 sensor on these models only use a narrowband sensor and will only adjust the AF mixture over a limited range of RPM and throttle opening.
I removed the O2 sensor, plugged in an O2 Sensor eliminator which sends a constant signal to the ECU so it wouldn't make any adjustments. PCV seems to work fine.
I wonder why Dynojet told you they don't have a PCV for the 2016 when the 2012-2015 Euro ZZR1400s do have an O2 sensor and they have a PCV for that (though they require an "O2 Optimizer"). Must be some other reason.
