Ruff Ryders Sky
posted March 12, 2017 10:40 AM
Sprocket Teeth Count
I currently have a 2009 ZX14. Changing out the Chain & Sprocket and wanted more torque. Would you all recommend 17 in the front and 47 or 48 in the rear? Also, I have questions about Power Commander as well, but I'll wait for one answer at a time!
wildncrazyguy
posted April 03, 2017 05:54 AM
I have the same bike. My new power commander is waiting for me at home- just came in the mail . I bought a 16t vortex for the front to start with. I was told this is the most bang for the buck. If Im not happy with that Ill go up 2 in the rear in addition. Need to be careful though unless you dont care about buying chains. Certain combinations will require you to switch out the chain for a different size. Going down one tooth in the front wont require a change in chain. DO a search on it . I did and saw somewhere a post where someone talked about what combinations will work with your stock 530 chain and which ones will require a different size chain.
wildncrazyguy
posted April 24, 2017 11:57 PM
I went to 16 in front - loved it. Going +2 in the rear next
Quick Reply: |
