KMC is recalling over 4,400 Concours14's for problems with the Saddlebags falling off, as well as problems with the Rear Luggage Rack potentially breaking.
If you own one of these bikes, check your VIN # and contact your local Kawasaki dealer for more information.
Saddlebag Recall
Click Here to download the PDF detailing this recall
The latch of the saddlebag(s) is subject to breakage if a large force is applied to the saddlebag (such as might happen if the motorcycle were to fall on its side even at a stand still) or to the latch (such as might happen if the operator tried to force the latch closed when the latching mechanism was not in the proper position). The broken latch may allow the saddlebag to separate from the motorcycle. If this were to occur in traffic, there is the risk of a crash and the possibility of injury or death.
2008 Models Affected...
ZG 1400A8F/A8FL
ZG 1400B8F/B8FL
JKBZGNAl / 8A005038 through JKBZGNA1 / 8A013534
JKBZGNB1 / 8A005008 through JKBZGNB1 / 8A007566
Top Box / Rear Rack Recall
The rear carrier platform may not be strong enough to withstand the longitudinal forces associated with mounting and use of certain common accessories. The rear carrier consists of a frame with a plastic load carrying platform. While the platform is fully capable of carrying the recommended weight, it may not be strong enough to withstand the fore-and-aft longitudinal forces that might be associated with mounting of a "top box" to the platform, particularly if the top box is used as a backrest by a passenger. In such a situation, the platform could break, creating the potential for an accident leading to a serious injury or death.
ZG 1400A8F/A8FL
ZG 1400B8F/B8FL
JKBZGNAl / 8A005038 through JKBZGNA1 / 8A011423
JKBZGNB1 / 8A005008 through JKBZGNB1 / 8A007204
