New 2009 Kawasakis are out! Photos & Info Here!
Kawasaki unveils its 2009 model lineup, including an all-new ultra light weight Ninja ZX-6R. New for 2009 is a redesign of the successful Ninja 650R. Europe's naked ER-6n makes its Stateside debut with a redesign. 2009 brings a new Vulcan 1700cc cruiser as well as new color availability for both the Concours14 and the flagship ZX-14. The road based KLX250S hits the streets reworked with an all new design drawing from the Ninja 250R engine. A surprise addition to the US model lineup is the brand new KLX250SF Supermoto! Details, specs and images follow...
2009 Kawasaki ZX-6R
2009 Kawasaki Ninja 650R
2009 Kawasaki ER-6n
2009 Kawasaki Vulcan 1700 series
2009 Kawasaki KLX250S
2009 Kawasaki KLX250SF
2009 Kawasaki Concours 14
2009 Kawasaki ZX-14
2009 Kawasaki ZX-6R
More ZX-6R pics below
Precise Control for Maximum Excitement
To truly push the envelope, a rider needs a calm yet responsive sportbike with precision control feel and confidence-inspiring manners. That machine is perfectly embodied by the new 2009 Ninja® ZX™-6R. Thanks to an extensive overhaul by the Kawasaki engineers; weight shaving, improving mass centralization, refining engine and chassis behavior, adding a revolutionary front fork design; the new leaner, more precise Ninja ZX-6R delivers the elusive calm and confident handling that top racers need.
Fine-tuning the chassis and tightening its mass centralization resulted in lighter handling to make it even easier to tip this ZX-6R into a corner. To optimize front-rear rigidity balance, the engineers revised frame stiffness around the swingarm pivot and the rear engine mounts. The engine was rotated around the output shaft to offer a steeper cylinder bank angle and raise its CG by 16mm. A new exhaust layout with a short side muffler lowers the weight previously located under the seat and an exhaust pre-chamber further contributes to the new ZX-6R’s mass centralization.
The new Ninja ZX-6R’s leaner physique is fundamental to its lighter handling. Both the engine and chassis were evaluated to reduce weight. The intake resonator box and supports for the instrument panel and mirrors are now unitized with the enlarged –to optimize intake volume – Ram Air duct, contributing to weight savings and improving rigidity. New camshafts are now made of lighter SCM, and lightweight magnesium replaces aluminum for the engine covers. Revised internal gears – transmission, oil pump and starter – are lighter without compromising strength. Adjusting several mounting plates and the coolant reservoir locations helped shave additional weight.
Handling wasn’t the only area of improvement on the new Ninja ZX-6R; its lighter engine received a host of changes focused on delivering precise throttle control and increased performance, particularly in the mid-range. A smoother power delivery was achieved through better combustion efficiency. The changes include; adding cylindrical guides to the top of the airbox to better guide the fuel charge into the intake funnels, increasing the distance between the main and sub-throttles by 10mm to reduce inlet turbulence, revised cylinder porting to improve cylinder filling and increasing secondary coil current in the ignition coils.
In addition to healthier bottom-end torque and smoother throttle response, the engine’s mid-range performance was increased via a similar number of refinements, including; new double-bore velocity stacks with inlets at two different heights, pistons with new profiles and improved crown finishing, and reduced mechanical loss by decreasing piston ring tension and revising the cam chain guides to better stabilize the motion of the chain. A new exhaust collector layout rounds out the major changes.
The stronger mid-range torque provides greater drive out of corners and is harmonized with the engine’s silky smooth high-rpm performance. This linear throttle torque delivery results in improved controllability and offers the rider more precise throttle control at all rpm. This predictability pays dividends when making mid-corner power adjustments. When combined with the reduced need to downshift provided by its healthy mid-range performance, the predictable throttle response makes it easier for riders to maintain their rhythm when stringing corners together.
In keeping with its racing heritage, the ZX-6R employs a cassette-type transmission that simplifies gearing changes at the track, reducing set-up time and allowing more time for riding. A slipper clutch allows quick downshifts without upsetting the rest of the chassis when reducing speed on corner entry.
Corner-entry controllability receives a major performance boost, thanks to the first production-use of Showa’s revolutionary new BPF (Big Piston Front fork). The BPF utilizes a large-diameter internal piston, which permits a reduction in damping pressure, for smoother action and better front end feedback – especially under braking and initial corner turn-in. Additionally, the BPF eliminates many of the internal components used in a cartridge-type fork, simplifying construction and resulting in a lighter overall fork weight.
Having already designed a lighter and more rigid swingarm for the Ninja ZX-10R sportbike, the Kawasaki engineers utilized many of the same design components for the new ZX-6R’s swingarm. Shared swingarm parts include both left and right inner plates, the left outer plate, rear stand bosses, brake caliper stopper, chain guard and swingarm pivot shaft.
The response from Kawasaki’s acclaimed triple petal disc brake package with radial calipers was improved as well. The 220mm rear petal disc is now 10mm larger and features a revised brake lever that’s now coaxially mounted with the footpeg for increased mid-stroke braking efficiency and improved feeling. Its master cylinder reservoir was relocated forward of the swingarm – freeing up space around the footpeg, reducing parts and contributing to weight savings. Trackside maintenance is easier too, thanks to the revised front brake hose routing with a three-way joint at the lower triple-clamp to simplify bleeding the brake lines.
All of these revisions give the Ninja ZX-6R unflappable composure under braking and help provide the precise control and feel that allows Supersport racers to enter corners harder. To better capitalize on this lighter machine and its precise control response, the rider interface was appropriately fine-tuned to enhance feedback from the bike to the rider.
The relationship of the seat-to-pegs-to-bar “rider triangle” was adjusted slightly, with the handlebars moved closer to the rider and turned in slightly for a more intuitive riding position. The fuel tank cover is more flared around its top edge, providing a larger contact patch and contributing to improved rider feedback – similar to the ZX-10R. A new narrower rear sub-frame and seat leading edge, plus a 10mm lower seat height provide a slimmer riding position and a shorter reach to the pavement.
A new fairing and a less-complex one-piece front fender – previously a three-piece unit – offer improved aerodynamics and airflow to the radiator, better wind protection and help minimize the effect of crosswinds. The new inner rear fender, mounted above the swingarm, reduces turbulence and helps keep the tail clean. Like its bigger ZX-10R sibling, the ZX-6R received a new instrument panel that provides information at-a-glance and a race-quality adjustable Öhlins steering damper with relief valve and twin-tube design.
Highly confidence inspiring, the engine and chassis control precision offered by the new Ninja ZX-6R enables riders to push harder and maximize the excitement that comes from actively controlling such a high-performance track-focused machine.
Key Feature
- New leaner physique with a major reduction in weight and improved power delivery offer more precise control, lighter handling and better acceleration
Lightweight engine
- Camshafts are now made of SCM - saving approximately 400g
- Lightweight magnesium engine covers are standard and save approximately 610g over aluminum units
- Revised top injector mounting plate saves approximately 80g
- Narrower transmission gears and revised gear dog shape provide a 170g weight savings, without compromising rigidity
- Oil pump and starter gears are machined to use less metal, shedding approximately 70g
- New inlet pressure pulse monitor enables deletion of the cam angle sensor, further contributing to engine weight reduction
- Coolant reservoir relocated and redesigned, the new shape and shorter tube save approximately 150g
- Revised and relocated heat pads contribute another 170g to weight savings
- Reshaped secondary air passages through the cylinder head contribute to more efficient cleaning of exhaust emissions
- Cassette-type transmission makes it easy to quickly swap gear ratios, reducing set-up time at the track
Increased mid-range performance
- New double bore velocity stacks feature inlets at two different heights, increasing performance in both the mid- and high-rpm ranges
- Increased durability from optimized cam nitriding and tappets enable high-load cam profiles, which improve overall performance
- Pistons have new profiles and improved crown finishing
- Molybdenum coated piston skirts reduce friction and help with engine break-in
- Piston rings with less tension reduce mechanical loss
- Revised cam chain guides stabilize chain motion, further reduce mechanical loss
- New exhaust collector layout contributes to improved low and mid-range performance while maintaining high-rpm performance
More precise throttle control
- Cylindrical guides added to the top of the air cleaner box ensure more accurately sprayed fuel mist from the secondary injectors into the intake funnels, improving combustion efficiency
- Longer throttle bodies increase the distance between oval sub-throttles and round main throttles 10mm, yielding a smoother transition, which reduces inlet turbulence and increases efficiency
- Revised cylinder porting delivers improved cylinder-filling and scavenging
- New ignition coils have 12% greater secondary coil current for improved combustion efficiency, adding to the improved performance
Lightweight chassis
- The sub-frame is a 2-piece aluminum die-casting consisting of a front and rear section
- The new lightweight sub-frame is very narrow, for a compact and slim rear end
- Intake resonator box and supports for the instrument panel and mirrors are unitized with the Ram Air duct, contributing to weight savings and increased rigidity
- Frame brackets revised to reduce overall number of parts, which also contributes weight savings.
- New throttle housing material saves approximately 30g
Revised chassis balance and mass centralization
- Revised frame stiffness around the swingarm pivot and the rear engine mounts optimizes front-rear rigidity balance
- Engine is mounted with a steeper cylinder bank angle. Rotated around the output shaft, the engine’s CG is 16mm higher
- New exhaust layout with a short side muffler lowers weight previously located under the seat
- An exhaust pre-chamber further contributes to mass centralization
Ergonomics and chassis feedback
- Seat-pegs-bar relationship was adjusted slightly, with the handlebars moved closer to the rider and turned in slightly for a more intuitive riding position
- Fuel tank profile is more flared around its top, similar to the ZX-10R, providing a larger contact patch which contributes to improved rider feedback
- Slim, waist on fuel tank makes it easy for the rider to grip the tank with his knees or to hang off in turns
- Front to back, the new seat is shorter, allowing the rider to shift his body farther back on the rear seat step, helping to reduce rider fatigue
- Steeper rake angle quickens steering response and enhances communication from the front tire
- Relocating the rear brake master cylinder reservoir forward of the swingarm mount frees up space around the footpeg, enabling a reduction of parts and contributing to weight savings
Lower seat height
- New rear sub-frame is narrower, making it easier to reach the ground
- Front of seat is narrower and seat height is approximately 10mm lower, for a slimmer riding position and a shorter reach to the pavement
Advanced suspension
- ZX-6R features the first production-use of Showa’s new Big Piston Front fork (BPF) design
- The BPF eliminates many of the internal components used in a cartridge-type fork, simplifying construction and resulting in lighter overall fork weight
- The large-diameter of the BPF’s internal piston allows a reduction in damping pressure, for better feedback and smoother action
- The ZX-6R swingarm uses many of the same parts as the ZX-10R; both left and right inner plates, the left outer plate, rear stand bosses, brake caliper stopper, chain guard and swingarm pivot shaft
- Greatly improves braking and initial corner turn-in
- New 220mm rear petal disc is 10mm larger
- Revised rear brake lever is now mounted coaxially with the footpeg for increased mid-stroke braking efficiency and improved feeling
Race-quality steering damper
- A race quality adjustable Öhlins steering damper with relief valve and twin-tube design is fitted as standard equipment
Additional Features
- New fairing offers better wind protection and was designed to minimize the effects of cross winds
- Position lamps are now integral with the projector beam headlights; the new Ninja ZX-6R now features dual position lamps like the ZX-10R
- New one-piece fender (previously a three-piece construction) offers improved aerodynamics
- New inner fender above the swingarm helps to reduce turbulence and keep the undertail clean
- Revised front brake hose routing with a three-way joint at the lower triple-clamp facilitates bleeding air from the brake lines
- Similar in design to that of the ZX-10R, the new instrument panel gives at-a-glance information to the rider
Displacement: 599cc
Bore x stroke: 67.0 x 42.5mm
Compression ratio: 13.3:1
Fuel injection: DFI® with four 38mm Keihin throttle bodies, oval sub-throttles, two injectors per throttle body
Ignition: TCBI with digital advance
Transmission: Six speed
Final drive: X-ring chain
Rake / trail: 24 deg / 4.0 in.
Frame type: Aluminum perimeter
Rear tire: 180/55 ZR17
Wheelbase: 55.1 in.
Front suspension / wheel travel: 41 mm inverted Showa Big Piston Front fork with top-out springs, stepless compression and rebound damping, fully-adjustable spring preload / 4.7 in.
Rear suspension / wheel travel: Bottom-Link Uni-Trak® with gas-charged shock, top-out spring and pillow ball upper mount, dual-range (high/low-speed) stepless compression damping, 25-way adjustable rebound damping, fully-adjustable spring preload / 5.2 in.
Front brakes: Dual 300mm petal rotors with dual radial-mounted, four-piston, four-pad calipers
Rear brake: Single 220mm petal rotor with single-piston caliper
Overall length: 82.3 in.
Overall width: 27.8 in.
Overall height: 43.9 in.
Fuel capacity: 4.5 gal.
Seat height: 32.3 in.
Curb weight: 421.2 lbs.
Color choices: Lime Green, Metallic Diablo Black / Flat Super Black, Candy Surf Blue / Flat Super Black, Metallic Diablo Black with special Monster Energy graphics
MSRP: $9,799
More Ninja 650R pics below
Sportier Performance plus New Ninja Looks.
More than a pretty face with a good personality, this is a true Ninja sportbike
The Kawasaki Ninja® 650R already epitomized the ideal marriage of sportbike performance and relaxed comfort. For 2009 Kawasaki improved on this combination and gave this popular model several new upgrades, from improved suspension to updated Ninja supersport styling. The end result of over 40 updates and refinements, the new sportier Ninja 650R delivers serious performance fun and maximum transportation practicality.
The key to the Ninja 650R’s slender size is its compact liquid-cooled, fuel-injected, DOHC, 8-valve 649cc parallel twin engine, which permits the use of a narrow, lightweight frame. Revised fuel injection settings on this torquey engine boost its bottom-end torque, smooth low-mid rpm response and allow it to rev more quickly.
Routing the coolant to the cylinder and head through the engine cases reduces the number of external hoses. The engine also meets stringent Euro-III emission regulations thanks to its precise fuel-injection and a three-way catalyzer system with a new 300-cell catalyzer that’s smaller and lighter than the previous 200-cell unit.
The non-intimidating twin-cylinder appeals to new riders, and has an excellent mid-range that offers enough pizzazz to thrill more advanced riders. A modified shift lever position permits easier application of the Ninja 650R’s linear power delivery. The manageable power delivery and superb roll-on response enable the new Ninja 650R to make short work of the morning commute or perform as an entertaining track day companion – all while delivering good fuel economy.
This spunky sportbike received several changes to the frame, swingarm and suspension that result in reduced vibration and lighter handling, making the new Ninja 650R more nimble and comfortable than ever. Its signature trellis frame and offset laydown rear shock design remains, but the frame was completely revamped and now sports a higher quality paint finish.
The slim, compact trellis style chassis received more than cosmetic changes. Revisions to rigidity balance and suspension settings, and the addition of rubber upper-rear engine and handlebar mounts result in reduced vibration and lighter handling, enabling an improvement on the Ninja 650R’s comfort and handling.
Rider and passenger footpegs are now rubber coated to further reduce the amount of vibration transferred to the rider. The natural riding position and ergonomics are enhanced by a new slimmer and lower seat, which makes reaching the ground even easier than on the previous model.
Surrounding the Ninja 650R’s updated chassis is unquestionably sportier styling. From the wider windscreen and dual headers to the high-quality finish of the sleek minimalist fairings and covers leave little doubt about this Ninja’s supersport genetics.
Avoiding unnecessary design flourishes, the Ninja 650R’s new sharper lines flow throughout the bike, giving it an aggressive appearance. Even with a new, taller fuel tank, the new fairing with integrated turn signals and a sharp tail cowl ably highlight this motorcycle’s compact dimensions.
Beyond its exciting appearance, new MotoGP inspired multi-function instrumentation and revised controls, the Ninja 650R is rolling proof that a performance motorcycle can be practical and comfortable. The rider may notice the slimness of the chassis, low seat height and minimal effort controls first before realizing the true aim of Kawasaki’s design efforts – the rider.
The Ninja 650R’s friendly ergonomics provide a versatile cockpit that both novice and experienced riders will use to employ its assets to the fullest, from the daily commute to a weekend canyon run. In other words, this real world overachiever easily demonstrates its versatility and everyday usefulness.
COMPACT, QUICK-REVVING ENGINE
The balance of compact size and good power offered by the Ninja 650R's predecessor was the key to its success. To fit into its trim package, an in-line four would have been too wide and a V-Twin too long. The only engine design that offered both good power characteristics and the requisite compactness was a Parallel Twin. While maintaining this balance, the new engine gets a number of tweaks that offer smoother low-mid response and a quicker-revving character.
LIGHT-HANDLING CHASSIS
The key to the Ninja 650R’s compact size is its amazingly compact Parallel Twin engine, which permits the use of a narrow, lightweight frame. The result is a bike with the dimensions of a 400 and the power of a 650 that welcomes beginners with a “Come on, let’s go for a ride!” attitude, while also offering plenty of performance for more experienced riders. Changes to the frame, swinging arm and suspension result in reduced vibration and lighter handling, making the new Ninja 650R more accessible than ever.
SLEEK, SUPERSPORT STYLING
Styling inspired by our Ninja supersport models gives the front fairing of the Ninja 650R the look of a modern supersport machine. Sharp edged lines move forward, giving the bike a more aggressive, crouching appearance. Simple in design, the Ninja 650R avoids all superfluous design flourishes; lines were made to flow as long as possible. The new, taller fuel tank, minimalist-design bodywork and sharp tail cowl give the bike a compact, purposeful appearance. Attention to the smallest detail contributes to the new bike’s high-quality finish and undoubted appeal.
Engine: Four-stroke, liquid-cooled, DOHC, four-valve per cylinder, parallel twin
Displacement: 649cc
Bore x stroke: 83.0 x 60.0mm
Compression ratio: 11.3:1
Maximum torque: 48.5 lb/ft @ 7,000 rpm
Cooling: Liquid
Fuel injection: Digital fuel injection with two 38mm Keihin throttle bodies
Ignition: Digital CDI
Final drive: O-ring chain
Frame: Semi-double cradle, high-tensile steel
Rake / trail: 25 degrees / 4.2 in.
Wheelbase: 55.5 in.
Front suspension / wheel travel: 41mm hydraulic telescopic fork / 4.7 in.
Rear suspension / wheel travel: Single offset laydown shock with adjustable spring preload / 4.9 in.
Front tire: 120/70x17
Rear tire: 160/60x17
Front brake: Dual 300mm petal discs with two-piston calipers
Rear brake: Single 220mm petal disc with single piston caliper
Overall length: 82.9 in.
Overall width: 29.9 in.
Overall height: 50.0 in.
Seat height: 31.1 in.
Curb weight: 440.9 lbs.
Fuel capacity: 4.1 gal.
Colors: Lime Green
Passion Red
MSRP: $6,799
Warranty: 12 months
2009 Kawasaki ER-6n
More ER-6n pics below
Muscular street fighter looks with an easy going personality
Riders seeking the performance and practicality of Kawasaki’s popular Ninja® 650R sportbike, but desiring something with a tougher, more muscular image need look no farther than the new 2009 Kawasaki ER-6n. Sharing mechanicals with the Ninja 650R, but with street-smart styling that reveals its trellis frame and compact parallel-twin engine, the ER-6n offers a unique blend of stunning good looks combined with nimble handling and a comfortable riding position. The ER-6n has all the performance of its Ninja sibling, in a new and distinctive guise.
The key to the ER-6n’s slender size is its compact liquid-cooled, fuel-injected, DOHC, 8-valve 649cc parallel twin engine, which permits the use of a narrow, lightweight frame. Its fuel injection settings grant the engine plenty of bottom-end torque and smooth low-mid rpm response. Its coolant is routed to the cylinder and head through the engine cases, reducing the number of hoses and simplifying the cooling system.
The size-efficient engine delivers good fuel economy and also meets stringent Euro-III emission regulations thanks to its precise fuel-injection and a new three-way catalyzer system equipped with a small and light 300-cell catalyzer.
The non-intimidating twin-cylinder appeals to riders with its excellent mid-range and plenty of character to thrill more advanced riders. This manageable powerplant offers superb roll-on response and enables the ER-6n to fluently slice through commuter traffic or carve canyons like a skilled surgeon.
The new ER-6n shares its signature trellis frame, offset laydown rear shock, swingarm, suspension and its chassis with the new Ninja 650R. The chassis rigidity balance and suspension settings, and the rubber upper-rear engine and handlebar mounts offer vibration dampening and lighter handling qualities. The rider and passenger footpegs are also rubber coated for a further reduction in the amount of vibration transferred to the rider. A slim and low seat further enhances the ER-6n’s natural riding position and makes reaching the ground painless.
Part of the ER-6n’s distinctive character is its sharp, muscular bodywork that gives it an aggressive, dynamic persona. The ER-6n’s bodywork accentuates the frame, rather than hiding it. The angular lines and simple design flows through the frame, rear suspension and swingarm creating an integrated line running from the steering head to the rear hub. Its tall fuel tank, raked-back radiator shrouds and sharp tail cowl further enhance the bike’s front-to-back compactness. The attention to detail is evident in the ER-6n’s high-quality paint finish.
The instrument cluster is uniquely stacked with a sharp design and easy layout from the analog speedometer to the multi-function LCD screen. The instrumentation features include a new fuel gauge, bar-style digital tachometer, clock, odometer and dual trip meters. Besides the rubber coating on the footpegs, the passenger also benefits from the easy to reach aluminum grab rails — nothing like a relaxed passenger to allow the rider to fully enjoy the ER-6n’s friendly ergonomics and a versatile cockpit.
Quite simply, this is a motorcycle that both novice and experienced riders can be at home on and equally comfortable employing its assets to the fullest, whether it be navigating urban environs or enjoying a weekend canyon run. In other words, this real world overachiever begs to demonstrate its versatility and everyday usefulness.
Quick-Revving, 649cc Parallel-Twin Engine
- Liquid-cooled, DOHC, 8-valve fuel injected twin cylinder delivers smooth, responsive performance, especially in the low to medium rpm range
- Excellent mid-range power, exceptional roll-on response and impressive passing performance make even commuter traffic enjoyable
- Silky smooth engine vibes via a 180° crankshaft driven balancer shaft, which in turn drives the water pump
- Oil jets on the connecting rod big ends spray oil on the undersides of the pistons to aid cooling
- Lightweight plug-mounted ignition coils deliver a hot spark and save space
- Wide radiator offers plenty of cooling efficiency
- New coolant routing travels directly to the engine cases, then on to the cylinder and head through internal passages, which reduces external plumbing and keep the cooling system simple
- Fine-tuned shift lever position is easy to use
Digital Fuel Injection
- Fuel injection settings permit a healthy bottom-end torque while letting the engine rev fast
- Sub-throttle valve equipped 38mm Keihin throttle bodies offer optimum performance and rideability
- Located behind the main throttle valves, the sub-throttles are controlled by the DFI® system ECU for a precise throttle response, similar to a constant-velocity carburetor
- Auto-fast idle system simplifies starting and helps ensure the catalyzer reaches optimum temperature quickly
- The lightweight fuel pump is mounted inside the fuel tank.
Compact Engine Design
- Powerful twin-cylinder engine is the most compact in its category, which helps reduce the dimension of the entire motorcycle and allows use of a slim, minimalist frame
- Triangular setup of the crankshaft and transmission shafts makes the engine short front-to-back
- Transmission input shaft, output shaft and change drum are contained in a “cassette”-style package that allows a compact layout and eases transmission maintenance chores
- Semi-dry sump design reduces engine height
- Plated, linerless aluminum cylinders with a narrow cylinder pitch keep the engine light and slim
Cleaner Emissions
- Efficient fuel injection and a three-way catalyzer inside the exhaust produce very low emissions, able to pass the stringent Euro-III emission regulations
- Utilizes a compact and light 300-cell catalyzer unit
- Under-engine muffler placement improves mass centralization and the bike’s low center of gravity
- The exhaust pipe bend and under-engine muffler arrangement contribute to the ER-6n’s attractive styling
Good Vibrations
- Rubber upper-rear engine mounts decrease the vibration transferred to the rider through the seat
- Handlebar is rubber-mounted to lessen vibration transmitted through the handle grips
- Rider and passenger footpegs are rubber coated to further reduce vibration
Lighter Handling Trellis Frame
- Frame has all the key ER-6n elements — slim, low, lightweight and compact design that is narrow at the knees and footpegs for rider comfort and control
- The strong, high-tensile steel trellis frame not only looks lightweight, but it is – rivaling that of aluminum frames
- Featuring balanced rigidity, achieved through extensive 3D analysis translates directly into superb handling
- The frame, rear suspension and swingarm designs flow together with an integrated line running from the steering head to the rear hub
- Short front-to-back dimensions of the engine allow for a long swingarm and a short wheelbase combination that contributes to the light and nimble handling
Rigid Swingarm
- Swingarm stiffness to balance the frame rigidity – due primarily to the rubber engine mounts
- The D-shaped cross-section swingarm, stabilizer, chain adjuster design and elegant one-piece rider/passenger footpeg stays complement to the ER-6n’s high-quality appearance
- Front and rear suspension settings to match the frame and swingarm rigidity values for lighter, rider-friendly handling
- Shape of the 41mm fork lower ends around the axle shaft adds to the bike’s performance and high quality image
Confidence Inspiring Ergonomics
- An ideal handlebar, seat and footpeg relationship results in a comfortable and natural riding position suiting a wide range of riders
- Frame narrows just aft of the fuel tank enabling a slimmer seat, making the reach to the ground even easier
- The offset single-shock rear suspension layout with the battery located beside the shock instead of beneath it allows a lower seat height as well
- Low seat height and slim overall design make it easy to plant both feet firmly on the ground when stopped
- Aluminum passenger grips are positioned and shaped for easy grabbing by the passenger
Sharp Masculine Styling
- Angular, stacked dual headlight and its shroud contribute to the ER-6n’s masculine image and features two position lights
- Headlights can be adjusted behind the headlight cover
- Reinforcing the ER-6n’s masculine styling, the sharp, edgy radiator shrouds feature integrated front turn signals with clear lenses and orange bulbs and forward-leaning lines
- A flush-surface fuel cap and its sharp-edged motif give the tank a distinctive look
- The new ER-6n’s compact front-to-rear appearance is enhanced by the short front cowl, short rear cowl with its LED tail light and shrouds that start behind the front fork
- Finishing out the bike’s aggressive image is a sharp tail cowl design featuring a slimmer rear mud flap and turn signals that can also function as hazard lights
- A long front fender keeps the mud splashing to a minimum and its two-tone design matches the ER-6n’s light, compact theme
- An inner rear fender helps keep the underside of the tail cowl clean
- Storage options include four tie-down hooks for baggage or a spare helmet to be secured to the seat and a storage space under the seat with room for a U-lock or similar device
Mirrors
- Mirror design is a similar supersport-style and offer an unparalleled rear view
- Dual 300mm front petal disc brakes with twin 27mm piston front brake calipers and a single 220mm rear petal disc deliver plenty of braking power
- Housed in a curved brake master cylinder reservoir , the front brake lever utilizes an optimized ball-joint and pivot location to deliver smooth actuation of its 14mm master cylinder piston
Wheels
- Attractive six-spoke supersport-style wheels augment the bike’s light look while reducing unsprung weight
Instruments/Controls
- Stacked instrument cluster has a sharp design and clean layout with an analog speedometer that uses white LED backlights for excellent visibility at night
- The multi-function LCD screen has amber backlighting and its features include a fuel gauge, bar-style digital tachometer, clock, odometer and dual trip meters
- Inner cover inside the front cowl provides a clean appearance in this area
- Handlebar mount design and curved shapes on the brake master cylinder reservoir and clutch lever contribute further to the ER-6n’s masculine appearance
Displacement: 649cc
Cooling: Liquid
Rake / trail: 24.5 degrees / 4.0 in.
Wheelbase: 55.3 in.
Overall length: 82.7 in.
Overall height: 43.3 in.
Seat height: 30.9 in.
Curb weight: 442 lbs.
Color: Candy Plasma Blue
MSRP: $6,399
Warranty: 12 months
2009 Kawasaki Vulcan 1700 Series
More Vulcan 1700 pics below
Introducing a New Series of 1700cc V-Twin Cruisers
For 2009, Kawasaki is proud to introduce its newest series of big V-Twins. The Vulcan 1700 series, successors to the Vulcan 1600 models, all featuring powerful 1700cc engines, confidence inspiring handling and trademark Kawasaki craftsmanship.
The new engine design is similar to that of the mighty Vulcan 2000, but features a SOHC rather than OHV arrangement. Its increase in displacement and long-stroke design ensure both torque and horsepower gains over the Vulcan 1600 models. New features include Kawasaki’s first fully electronic throttle valve system, a new 6-speed transmission with overdrive, and belt final drive like the Vulcan 2000 and Vulcan 900 models.
The new lightweight chassis is more compact than that used on previous models. Chassis design and suspension settings result in light handling while maintaining good straight-line stability.
Bodywork and engine covers were completely redesigned. Like on all Kawasaki Cruisers, meticulous attention to detail and exquisite craftsmanship result in a motorcycle that turns heads whether parked in front of a café or cruising down the highway.
The Vulcan 1700 series is comprised of four models: Vulcan 1700 Voyager, Vulcan 1700 Nomad, Vulcan 1700 Classic and the Vulcan 1700 Classic LT. Variations in tuning and equipment mean there is a Vulcan 1700 model for all Kawasaki Cruiser fans.
Brief overview
Vulcan 1700 Voyager: Kawasaki’s first V-Twin “full-dress” tourer features all the comfort features, equipment and optional accessories necessary for long-distance two-up touring.
Vulcan 1700 Nomad: Cruise control, large windshield, hard panniers, passenger floorboards and luxury backrest enable comfortable two-up touring. Ideal for overnight or weekend tours with a passenger.
Vulcan 1700 Classic: Whether looking to ride around town or to escape the city for the day, the Classic offers a great V-Twin pulse, effortless handling and timeless looks.
Vulcan 1700 Classic LT: The LT adds just the right amount of accoutrements – a large windshield, leather saddlebags and a backrest – to make any solo or two-up venture around town or on the highway blissful..
First Ever Japanese Full-Dress V-Twin Tourer
Designed for those riders who set their sights beyond the horizon, the new Vulcan 1700 Voyager offers everything needed for comfortable long-distance touring… with or without a passenger.
Kawasaki’s first full-dress V-Twin, the new Voyager is equipped with a large front cowl and windshield, as well as leg shields for superior protection from the wind and elements. Ample storage care of a rear mounted “trunk”, hard panniers and dual glove boxes ensure that all the touring necessities, and even a few luxuries, can be accommodated.
Essential touring features like cruise control and a 6-speed transmission with an overdrive gear are joined by Kawasaki’s latest innovative technology. Kawasaki Advanced Coactive-braking Technology (K-ACT) complements rider actuated brake control with supplementary brake force enhancement for confident, highly effective braking in all situations. Kawasaki’s first fully Electronic Throttle Valve (ETV) system offers smooth, natural engine response.
The new 1700cc long-stroke liquid-cooled V-Twin engine offers increased torque and power output for superior passing performance. The new powerplant is mounted in a compact, lightweight frame that delivers both light handling and straight-line stability.
Engine: Four-stroke, liquid-cooled, SOHC, four valves per cylinder, V-twin
Displacement: 1,700cc / 103.7ci
Bore x Stroke: 102 x 104mm
Compression Ratio: 9.5:1
Maximum Torque: 108 lb-ft @ 2250
Cooling: Liquid, plus cooling fins
Induction: Digital fuel injection, dual 42mm throttle bodies
Ignition: TCBI with Digital Advance
Transmission: Six-speed with overdrive
Final drive: Belt
Frame: Steel, double-cradle with box-section single-tube backbone
Rake / Trail: 30° / 6.7 in.
Suspension, Front / Wheel Travel: 43mm hydraulic fork / 5.5 in.
Suspension, Rear / Wheel Travel: Swingarm with twin air-assisted shocks, with 4-way rebound damping / 3.1 in.
Front Tire: 130/90x16
Rear Tire: 170/70x16
Brakes, Front Dual 300 mm discs, dual twin-piston calipers
Brakes, Rear: Single 300 mm disc, twin-piston caliper
Overall Length: 98.4 in / TBD Voyager
Overall Width: 40.4 in / TBD Voyager
Overall Height: 45.5 in Classic / 57.7 in LT / 56.7 Nomad / TBD Voyager
Ground Clearance: 5.1 in.
Seat Height: 28.4 in. / TBD Voyager
Wheelbase: 65.6 in. / 66.5 Nomad / TBD Voyager
Curb Weight: 760.7 lb Classic / 804.8 lb LT / 822.5 lb Nomad / TBD Voyager
Fuel Capacity: 5.3 gal.
Classic Colors: Metallic Diablo Black, Luster Beige / Pearl Crystal White
Classic LT Colors: Metallic Nocturne Blue / Pearl Burnish Beige, Metallic Dark Green / Pearl Burnish Beige
Nomad Colors: Metallic Diablo Black, Two-tone: Candy Diamond Red / Pearl Luster Beige, Two-tone: Metallic Nocturne Blue / Pearl Luster Beige
Voyager Colors: Candy Diamond Red, Two-tone: Candy Plasma Blue / Metallic Diablo Black , Two-tone: Metallic Titanium / Metallic Diablo Black
More KLX250S pics below
A leaner, meaner and greener lightweight dual-sport machine
The fun doesn’t have to stop at pavement boundaries when riding Kawasaki’s street legal KLX™250S. This lightweight dual-purpose motorcycle is equally at home on the pavement or off-road and always ready for your next adventure. Now, thanks to significant updates that saw refinements made everywhere from its improved braking prowess to its aggressively styled bodywork, the KLX250S is more fun than ever.
Its compact, liquid-cooled, four-stroke, single-cylinder 249cc engine displaces and employs convenient electric-starting. The KLX250S’ engine is mounted beneath a lightweight, high-tensile steel perimeter frame to deliver a low center of gravity and enhanced maneuvering on tight trails.
A gear-driven engine balancer means reduced engine vibration for greater comfort and less fatigue on longer rides. The 34mm semi-flat slide Keihin CVK carburetor boosts throttle response and contributes to improved power. It also helps to provide increased fuel economy. The addition of a new evaporative emissions system allows it to meet strict CARB regulations, making the KLX250S eligible for sale in all 50 states.
Further refinements appear in the transmission. Closer ratios between 5th and 6th gear enhance the KLX250S’ high-speed off-road capabilities, while a reshaped shift cam offers a more positive shift feel and promotes firmer gear engagement.
The rigors of off-road motorcycling dictate additional protection for the exposed underside of most machines. The KLX250S comes standard with aluminum engine guards to protect its crankcase during off road adventures. Negotiating tight terrain also highlights another off-road reality – heat. The incorporation of dual lightweight, high-capacity Denso radiators and a shallow-footprint cooling fan is an ample solution to potential heat issues.
Its straight-line stability is enhanced by the rigid square-section frame, yet thanks to its short wheelbase the 250S still has outstanding turning aptitude. Complementing the chassis is a new lightweight aluminum swingarm employs a highly-rigid D-shaped cross section and features new KX racing-type chain adjusters for precise chain adjustment.
The new KLX250S also received revised damping settings and reduced wheel travel at both ends, plus an all-new rear suspension linkage. These modifications help to increase straight-line stability, give a more planted feel in corners and make it easier for riders to reach the ground. The 43mm inverted cartridge-style front fork features 16-way adjustable compression damping and 10.0-inches of travel while the revised Uni-Trak® rear suspension has 16-way adjustable compression and rebound damping and offers 9.1-inches of travel.
New wheels feature 0.5mm thicker spokes for increased wheel rigidity and enhanced off-road durability. The KLX250S also offers upgraded stopping power from a twin-piston caliper and a 250mm semi-floating petal disc up front and a larger 240mm petal disc at the rear.
Finishing off this reworked package is a completely new set of aggressively styled bodywork, a re-shaped seat with firmer urethane, and a handlebar with a straighter profile.
Riders seeking enduro handling and modern engine performance in a dual-purpose motorcycle designed for effortless street riding will find it at their local Kawasaki dealership. The KLX250S offers serious capabilities in a fun, easy-to-ride package, regardless of where the adventure takes it.
Single-cylinder 249cc DOHC Engine
- Compact engine design is lightweight and high revving, with a broad torque curve
- Good mass centralization for superior handling
- Flat-top piston and pentroof combustion chamber deliver an 11:1 compression ratio
- Lightweight piston, piston pin and connecting rod enable higher revs for maximum power
- Aluminum cylinder features electrofusion coating, which allows a tight piston-cylinder clearance for greater horsepower and offers increased engine life thanks to superior heat transfer and lubrication retention properties
- A gear-driven engine balancer provides smooth power delivery from idle to redline
Liquid Cooling
- Dual high-capacity, vertical-flow Denso radiators provide reliable and efficient engine cooling
- Radiators feature tightly packed cores and a fin design for excellent heat dispersion
- More consistent engine temperatures allow tighter engine clearances for quieter running and sustained power, while promoting longer engine life
- Cooling fan is powered by a shallow-footprint electric motor
Four Valve Cylinder Head
- Provides maximum valve area for optimum flow to boost low end torque while providing improved high-rpm breathing efficiency for more power
Revised carburetor settings
- 34mm semi-flat slide Keihin CVK carburetor delivers the optimum amount of fuel at all rpm, contributing to improved response and power, as well as good fuel economy
- Now available in California, thanks to new evaporative emissions system that meets strict CARB regulations
Electric Starting
- Quick and easy push-button starting
- Kawasaki Automatic Compression Release (KACR) automatically lifts one of the exhaust valves at cranking rpm, for reduced starting effort
Exhaust system
- Secondary air system helps provide clean emissions
- USFS-approved spark arrester allows the KLX250S to access designated off-road public riding areas
Updated Six-speed Transmission
- Allows engine’s full potential to be used
- Provides excellent acceleration as well as relaxed highway cruising
- Gear ratios amended to set 6th gear closer to 5th for improved performance
- Revised shift cam offers better feeling and allows gears to click into place with more precision
Improved Inverted Front Forks
- 43mm inverted cartridge fork offers excellent rigidity and consistent damping performance
- Reduced travel to 10.0 in. for increased straight-line stability, improved handling in corners and a lower seat height
- 16-Way compression damping adjustment allows tuning for differences in rider weight or various terrain profiles
UNI-TRAK® Rear Suspension
- All new linkage and revised damping settings reduce front-rear pitching motions
- Rear wheel travel reduced to 9.1 in, for increased straight-line stability, improved handling in corners and a lower seat height
- Progressive linkage rate provides a smooth ride and excellent bottoming resistance
- The gas-charged shock features 16-way adjustable compression and rebound damping and remote reservoir
Diamond Frame
- Lightweight, high-tensile steel for amazing rigidity
- No down tubes for lower engine placement and lower center of gravity
- Still has ample ground clearance
- New lightweight, aluminum D-section swingarm is highly rigid and reduces unsprung weight
- New KX racing-type chain adjusters allow precise adjustment to minimize drivetrain power losses
Enhanced Ergonomics
- Revised handlebar is straighter and offers a more relaxed position and effortless control
- Footpegs are positioned close to the bike’s centerline
- New seat shape and stiffer urethane makes it easier to change seating position
New Bodywork
- Aggressive new look courtesy of a new headlight and front fender design
- Two-piece radiator shrouds styled like the KX motocrossers
- Rear fender is a two-piece unit featuring a sharp tail light design that offers increased visibility and further contributes to the KLX’s aggressive styling
Narrow Fuel Tank
- Narrow tank design gives riders maximum comfort and control
Digital instrumentation
- All-digital instrument console gives at-a-glance information that includes a digital bar-graph tachometer, digital speedometer, clock, and dual trip meters
Petal disc brakes
- Front and rear disc brakes offer impressive stopping performance
- Twin-piston caliper grips a 250 mm petal disc up front
- Increased rear brake control provided by a revised lever ratio, new pad material and different caliper
- 240mm rear petal disc is 20mm larger than the old model
Wheels/tires
- New 4.0mm spokes offer increased wheel rigidity for greater off-road durability
- Tires feature smaller blocks for longer tire life and increased grip on asphalt
Engine: Four-stroke, Liquid-Cooled, DOHC, four-valve single
Displacement: 249cc
Bore x stroke: 72.0 x 61.2mm
Compression ratio: 11.0:1
Cooling: Liquid
Carburetion: Keihin CVK34
Rake / trail: 26.5 degrees / 4.1 in.
Front suspension / wheel travel: 43mm Inverted Cartridge Fork with 16-Way Compression Damping Adjustment / 10.0 in.
Rear suspension / wheel travel: Uni-Trak® with Adjustable Preload, 16-Way Compression and Rebound Damping Adjustment / 9.1 in.
Front tire: 80/100x21
Rear tire: 100/100x18
Front brake: 250mm semi-floating petal disc with two-piston hydraulic caliper
Rear brake: 240mm petal disc with single-piston hydraulic caliper
Overall length: 86.6 in.
Overall width: 32.3 in.
Overall height: 47.4 in.
Ground clearance: 11.2 in.
Seat height: 35.0 in.
Dry weight: 277.8 lbs (280 lbs CA model)
Fuel capacity: 2.0 gal.
Wheelbase: 56.3 in.
Color choices: Lime Green, Sunbeam Red
MSRP: $4,899
Warranty: 12 months
More KLX250SF pics below
Lightweight supermotard delivers quick reflexes and unlimited fun
For those seeking a nimble user-friendly bike with supermoto styling, Kawasaki has a solution in the shape of its new KLX™250SF. Based on the KLX250S dual sport, the new SF model is specifically tuned to deliver maximum on-road fun. Its 17-inch wheels, radial sportbike tires, a big front brake rotor and lowered suspension give it an air of purposeful aggression.
Sporting all of the updates and refinements found on the freshly minted KLX250S, the new KLX250SF has reduced wheel travel at both ends, placing the center of gravity lower to improve on-road handling and enhance straight-line stability. This also results in a more planted feel in corners and a lower seat height. The change in setup offers a firm ride quality, thanks to a change in front fork oil level and revised damping settings for both the fork and shock.
These changes provide a reduction in pitching motions during braking and acceleration and help allow the rider to hold a consistent line during aggressive on-road cornering. However, the suspension is still supple enough to soak up most road surface irregularities and offer a smooth ride. The KLX250SF’s fully-adjustable suspension features 16-way adjustable compression and rebound damping on both the 43mm inverted cartridge-style front fork and the Uni-Trak® rear suspension. Wheel travel is 9.1-inches front and 8.1-inches rear which strikes a happy-medium between long-travel off-road designs and short-travel sportbikes.
The KLX250SF’s short wheelbase aids its already outstanding ability to hold tight lines and its rigid box-section perimeter frame provides excellent transitional response, thanks to it’s rigid steering head. Complementing the chassis is a lightweight aluminum swingarm with a highly-rigid D-shaped cross section and KX™ racing-type chain adjusters for precise chain adjustment.
The new KLX250SF employs convenient electric-starting for its compact, liquid-cooled, four-stroke, single-cylinder engine. The 249cc engine is mounted in a lightweight, high-tensile steel perimeter frame to deliver a low center of gravity and superb maneuvering on tight roads. A gear-driven engine balancer keeps engine vibrations at bay for greater comfort and less fatigue on long rides.
A 34mm semi-flat slide Keihin CVK carburetor contributes to quick throttle response and precise power delivery. It also helps to provide increased fuel economy. An evaporative emissions system allows the KLX250SF to meet strict CARB regulations, making it eligible for sale in all 50 states.
A six-speed transmission provides optimum gearing for most occasions and helps the rider to keep the 249cc engine at its optimum rpm. It employs a smaller 39-tooth rear sprocket to extend its high-speed capabilities beyond those of the KLX250S dual sport.
Negotiating urban traffic or blasting around a tight race track highlights another strength of the KLX250SF – it keeps its cool. Incorporating dual lightweight, high-capacity Denso radiators and a shallow-footprint cooling fan provides an ample solution to potential heat issues.
New 17-inch cast aluminum wheels offer great handling, improved stability and the aggressive on-road performance sought by urban commandos and canyon carvers. The new wheels also allow access to a wide range of sportbike tire options. Aggressive riding on pavement demands powerful, fade-resistant stopping capabilities and the new KLX250SF delivers with a massive 300mm semi-floating petal disc up front clamped by a twin-piston caliper. The rotor is 4.0mm thick for increased rigidity, efficient heat dissipation, and optimum fade resistance. A single-piston caliper squeezing a 240mm rear petal disc compliments the big front brake.
Finishing off this package is a new set of aggressively styled ebony bodywork, a comfortable seat and a handlebar which offers good leverage so riders can flick the light KLX250SF side to side, or hold a tight cornering line with a minimum of effort.
Riders seeking supermoto handling and modern engine performance in a lightweight motorcycle designed for exciting street rides will find it at their local Kawasaki dealership. The KLX250SF offers serious capabilities in a fun, easy-to-ride package, regardless of where the adventure takes it.
- 34mm semiflat slide Keihin CVK carburetor delivers the optimum amount of fuel at all rpm, contributing to quick response and healthy power, as well as good fuel economy
Liquid Cooling
- Provides maximum valve area for optimum flow to for low end torque and efficient high-rpm breathing for more power
Electric Starting
Cleaner Emissions
- An evaporative emissions system that meets strict CARB regulations means the KLX250SF is available in California too
- USFS-approved spark arrester allows the KLX250SF to access designated off-road riding areas
- Matched to revised a 14/39 final gearing to enhance its open road performance
Inverted Front Fork
- Reduced travel to 9.1 in. for increased straight-line stability, more-consistent handling in corners and a lower seat height
- 16-way compression and rebound damping adjustment allows tuning for differences in rider weight or various terrain profiles
- Linkage and damping settings fine-tuned for optimum street performance and reduced front-rear pitching motion
- Rear wheel travel reduced to 8.1 in for enhanced straight-line stability, handling in corners and a lower seat height
- Lightweight, aluminum D-section swingarm is highly rigid and reduces unsprung weight
- KX racing-type chain adjusters allow precise adjustment to minimize drivetrain power losses
Perimeter Frame
Easy Ergonomics
- Handlebar offers a relaxed position and effortless control
- Seat shape and stiff urethane makes it easier to change seating position
Aggressive Bodywork
- Headlight and front fender design contribute to the aggressive look
Narrow Fuel Tank
- Narrow tank design gives riders maximum comfort and control without sacrificing capacity
Petal disc brakes
- Twin-piston caliper grips a 300 mm petal disc up front and a single-piston caliper grips the rear 240mm petal disc
Wheels/tires
- Features 17-inch wheels like its larger supersport brothers for excellent road handling
- Low-profile sportbike tires on wide rims contribute to its easy, neutral handling at low speedsSingle-cylinder 249cc DOHC
Displacement: 249cc
Cooling: Liquid
Rake / trail: 25.5 degrees / 2.9 in.
Front suspension / wheel travel: 43mm Inverted Cartridge Fork with 16-Way Compression and Rebound Damping Adjustment / 9.1 in.
Rear suspension / wheel travel: Uni-Trak® with Adjustable Preload, 16-Way Compression and Rebound Damping Adjustment / 8.1 in.
Front tire: 110/70x17
Rear tire: 130/70x17
Front brake: 300mm semi-floating petal disc with two-piston hydraulic caliper
Overall length: 83.9 in.
Overall width: 31.3 in.
Overall height: 44.9 in.
Ground clearance: 8.9 in.
Seat height: 33.9 in.
Curb weight: 302.1 lbs.
Wheelbase: 55.9 in.
Color: Ebony
MSRP: $5,299
Warranty: 12 months
The 2009 rendition of the Concours gets 2 new colors: Metallic Diablo Black and Candy Diamond Red.
2009 Kawasaki ZX-14
The 2009 ZX14 is available in 3 new color schemes: Candy Lime Green with Flat Super Black, Special Edition Candy Burnt Orange with Metallic Diablo Black, and Metallic Diablo Black with Monster Energy Graphics.
