American Honda release their all new 2011 CB1000R, derived from the 1000RR. This bike is Honda's entry into the naked class, now served by all the OEMs. The 1000RR engine appears to have been re-tuned for the street, while the chassis features a reappearance of Honda's signature single sided swingarm.
Honda says:
American Honda Motor Company's Powersports Division announced to its dealers today the release of the CB1000R, a high-performance and versatile "naked bike."
"Last week we introduced the all-new entry-level CBR250R and we're just as excited about this addition to Honda's lineup for 2011," said Powersports Press Manager Bill Savino. "The CB1000R fills a great position in today's market as we now bring a very capable sport machine packed with high-performance features to riders who focus on street use—wherever and whatever their destination may be. Whether it's a quick trip down a favorite backroad, a weeklong ride through a few states, or anything in between, the CB1000R is versatile enough to do it all."
More detailed information and images of Honda's model line can be found on powersports.honda.com or see your local Honda powersports dealer.
CB1000R: A Distinctive High-Performance Honda
When you look at the new CB1000R, you see a motorcycle with roots that stretch back to the seminal four-cylinder classic CB750K0 introduced by Honda in 1969. Yet at the same time the CB1000R carries a sporting heritage so modern that it will attract many of today's most sophisticated and demanding street riders.
Credit its clean, essentials-only styling, and a fuel-injected four-cylinder 998cc powerplant tuned for loads of right-now power. Sophisticated Gravity Die-Cast technology creates a mono-backbone aluminum frame that is strong yet features thin-wall construction for light weight. The distinctive single-sided aluminum swingarm features a single rear shock with spring preload and rebound-damping adjustability for excellent rear suspension action. And there's a fully adjustable 43mm inverted fork and radial-mounted dual 310mm disc brakes up front. Perhaps best of all, the roomy seating position delivers excellent rider comfort and tremendous versatility for long-distance travel and two-up riding. With all these features and more, the 2011 CB1000R is the most modern iteration of a long line of much-respected high-performance unfaired four-cylinder bikes—the classic hot-rod Hondas. Available in Pearl Black beginning in Spring 2011.
Look at the new CB1000R and you see a motorcycle with an enduring correctness of design. This is a motorcycle with roots that stretch back to the seminal four-cylinder classic CB750K0 introduced by Honda in 1969, a heritage that will resonate with a remarkably wide span of today's most sophisticated and demanding riders.
Credit its clean, essentials-only styling, a fuel-injected four-cylinder 998cc powerplant tuned for loads of right-now power, single-sided swingarm with single-shock rear suspension, plus a wealth of new features that give it its own unique identity. Whether you choose to call it a "naked bike," or a Superbike in Clark Kent clothing, the 2011 CB1000R is the most modern iteration of a long line of much-respected high-performance unfaired four-cylinder bikes—the classic hot-rod Hondas.
* The CB1000R powerplant features a sport/racing heritage in the form of a compact, lightweight and powerful 998cc liquid-cooled fuel-injected inline four-cylinder engine that has been specifically retuned for a street-savvy ride with impressive amounts of low-end and midrange power.
* The crankshaft, main shaft and countershaft are situated in a triangulated configuration, with the countershaft located below the main shaft, to dramatically shorten the overall engine dimensions from front to back.
* Racing-derived 16-valve cylinder head delivers outstanding flow for optimum combustion characteristics and power production.
* Aluminum composite cylinder sleeves are high-pressure formed from sintered aluminum powder impregnated with ceramic and graphite. The lightweight composite sleeves provide enhanced wear resistance and superior heat dissipation compared to conventional sleeves.
* Programmed Fuel Injection (PGM-FI) continuously monitors several variables to ensure the correct fuel mixture for the existing riding and atmospheric conditions, thereby delivering optimal performance and remarkably crisp throttle response over a wide range of operating conditions.
* Sophisticated Gravity Die-Cast technology creates a mono-backbone aluminum frame that is strong yet features thin-wall construction for light weight. This innovative technology forms the basis of a well-integrated chassis package that yields superb handling.
* Distinctively styled single-sided aluminum swingarm with single HMAS shock featuring spring preload and rebound-damping adjustability provides excellent rear suspension action along with a unique look.
* Up front, a fully adjustable 43mm inverted fork with radial-mount dual 310mm disc brakes sourced from the CBR1000RR offers leading-edge sport bike performance.
* Standard seating position delivers excellent rider comfort and tremendous versatility for long-distance travel and two-up riding.
* Short, compact and lightweight seat and tail cowl are both attractive and functional.
* Compact and stylish three-section LCD instrument panel features a multi-segment LCD tachometer.
* Distinctive triangular multi-reflector headlight, with unique LED position light.
* Distinctive cast aluminum wheels feature a swept four-spoke design.
Engine Type: 998cc liquid-cooled inline four-cylinder
Bore And Stroke: 75mm x 56.5mm
Induction: PGM-FI Fuel injection with automatic enrichment circuit and 36mm throttle bodies
Ignition: Computer-controlled digital transistorized with 3-D mapping
Compression Ratio: 11.2:1
Valve Train: DOHC; four valves per cylinder
DRIVE TRAIN
Transmission: Close-ratio six-speed
Final Drive: #530 0-ring chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension: 43mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.7 inches travel
Rear Suspension: Single gas-charged HMAS shock with spring preload and rebound damping adjustability; 5.0 inches travel
Front Brake: Dual radial-mounted four-piston calipers with 310mm discs
Rear Brake: Single 256mm disc
Front Tire: 120/70ZR-17 radial
Rear Tire: 180/55ZR-17 radial
DIMENSIONS
Rake: 25.0 degrees (caster angle)
Trail: 99mm (3.9 inches)
Wheelbase: 56.9 in
Seat Height: 32.5 inches
Fuel Capacity: 4.5 gallons, including 1.0-gallon reserve
Curb Weight: TBD
OTHER
Emissions: Meets current EPA standards. Models sold in California meet current CARB standards and may differ slightly due to emissions equipment.
Colors: Pearl Black
MSRP: TBD
