This morning Kawasaki released their 2015 incarnation of the ZX-10R and ZX-6R Superbikes. Both units, billed as 30th Anniversary edition models, carry WSBK inspired graphics packages and are available in ABS and non ABS versions.
Details such as green fork tube caps and green rear shock springs pretty much top off any changes to these already proven and successful models - there are no changes under the hood.
MSRP for the machines holds itself at peaky 2014 levels - Ranging from $14,299 for non ABS to $15,299 for ABS. Add $300 for the Anniversary graphics package.
The ZX-6R still ranges from $11,699 to $12,999 for an ABS equipped unit - toss in another 300 bones for anniversary mode.
Full details, specs and pics from Kawasaki below...
2015 KAWASAKI NINJA® ZX™-10R ABS
World Championship Winning Performance with Rider Friendly Electronics
With scintillating engine performance, a world-championship level chassis and a suite of onboard electronic rider aids, the ZX™-10R ABS is not only the most sophisticated production superbike Kawasaki has ever produced, it's also the most tunable, the most confidence inspiring, and the most rider-friendly. By any measure, Kawasaki’s “Forever Fearless” mantra is perfectly suited to the ZX-10R, thanks to its extraordinary performance envelope. Today, that much is expected in the one-liter superbike class. And so it is above and beyond these credentials that the ZX-10R ABS defines itself, including such premium standard features as Sport-Kawasaki Traction Control (S-KTRC), Kawasaki Intelligent anti-lock Brake System (KIBS) and an Öhlins electronic steering damper. Now celebrating Ninja’s 30th Anniversary, for 2015 the ZX-10R ABS is also available in a special anniversary edition that makes its bold credentials even more alluring.
What’s New For 2015
• A special 30th Anniversary Ninja ZX-10R ABS model features Lime Green/Pearl Stardust White paint and 30th Anniversary badges on each side of the fairing
• The standard Ninja ZX-10R model is now painted in Metallic Matte Carbon Gray/Flat Ebony
Engine & Transmission
The World Superbike Championship proven ZX-10R engine is a 16-valve, DOHC, liquid-cooled inline-four displacing 998cc through oversquare 76 x 55mm bore and stroke dimensions. Tuned for optimal power delivery on the street or track, the engine is also designed for a low center of gravity and ideal placement within the chassis, leading to more responsive handling.
Linear power delivery and engine manageability assist the rider through every element of cornering, beginning with a closed throttle at corner entry, resuming a neutral throttle position at mid-corner, and strong, controllable acceleration at corner exit. Placing the torque peak at a relatively high rpm level – closer to the engine’s horsepower peak – eliminates the power peaks and valleys, found in some engines, that make it difficult for racers and track-day riders to open the throttle with confidence.
Large intake valves are complemented by wide, polished intake ports for controllable power delivery and engine braking, just right for smoothing out racetrack corner entries and exits. Manufactured from chromoly steel, the dual overhead camshafts further contribute to optimized engine braking and more controllable power delivery. Lightweight pistons mount to light and strong connecting rods, and yield a full 13.1:1 compression ratio.
Like the ZX-6R, the ZX-10R has a race-style cassette transmission that allows simple trackside ratio changes. An adjustable back-torque limiting clutch assembly is fitted, which helps improve smoothness and rider confidence during quick downshifts and corner entry.
Delivering fuel and air into the engine is a ram-air assisted fuel injection system featuring an enormous nine-liter capacity airbox, large 47mm throttle bodies and sub-throttle valves, and secondary injectors that improve top-end power characteristics. A huge ram-air intake is positioned close to the front of the bike for efficient airbox filling and peak power.
The final piece of the ZX-10R’s power-production formula is an exhaust system featuring a race-spec titanium header assembly, hydroformed collectors, a large-volume pre-chamber containing two catalyzers, and a highly compact silencer. The header pipe diameter and length are very similar to race–use headers. This makes it easy to increase circuit performance just by adding a competition-use only slip-on muffler.
Motorcyclists are continually challenged by traction-related issues – whether on the street, track or off road. This is especially true for riders of open-class sportbikes, whose power and dynamic capabilities exceed the performance of top-shelf race bikes from just a few years ago. Given the huge performance envelope of the 2015 ZX-10R, consistent traction and enhanced confidence are major assets.
The ZX-10R’s racing-derived Sport-Kawasaki Traction Control (S-KTRC) system works by analyzing data from a variety of sensors including front and rear wheel speed, engine rpm, throttle position, acceleration and more. Conditions are confirmed every 5 milliseconds, at which time the system looks at each of the parameters as well as how much they are changing. This unique Kawasaki method makes it possible to interpolate and predict how the bike will behave in the next instant. In fact, the ZX-10R data acquisition and analysis is greater than any other Kawasaki in history – and it’s all to help track riders inch closer to the elusive “edge” of maximum traction than ever before. The S-KTRC system relies on complex software embedded in the ZX-10R’s Electronic Control Unit (ECU), with lightweight speed sensors on each wheel as the only additional hardware.
Unlike the KTRC system on Kawasaki’s Concours® 14 ABS sport tourer, which primarily minimizes wheel slip on slick or broken surfaces as a rider aid, the S-KTRC system is designed to maximize performance by using sophisticated computer analysis to predict when traction conditions are about to become unfavorable. By quickly but subtly reducing power just before the amount of slippage exceeds the optimal traction zone, the system – which processes every data point 200 times per second – maintains the optimum level of tire grip to maximize forward motion with a minimum of intrusion felt by the rider. The result is significantly better lap times and enhanced confidence – exactly what riders need when piloting a machine of this caliber.
The S-KTRC system offers three different modes of operation, which riders can select according to surface conditions, personal preference and skill level: Level 1 for maximum grip on the track; Level 2 for intermediate use; and Level 3 for slippery conditions. An LCD graph in the multi-function instrument display shows how much electronic intervention is occurring in real time, and a thumb switch on the left handlebar pod allows simple, on-the-go mode changes to suit the rider’s style. Riders may also turn the system completely off for total manual throttle control.
Chassis & Suspension
With the engine producing a massive quantity of usable and controllable power, engineers focused on refining the handling and overall road/track competency of the chassis. The cast-aluminum twin-spar frame is created from just seven pieces and features optimized flex characteristics for ideal rider feedback, cornering performance and light weight. The swingarm is also cast-aluminum, with rigidity engineered to match the frame.
Chassis geometry offers excellent handling and stability. The front-end geometry – 25 degrees of rake and 107mm (4.21 in.) of trail – allows light, quick handling along with reassuring stability at speed, perfectly complementing the engine’s controllable power and the frame and swingarm’s flex characteristics.
Highly advanced suspension helps the ZX-10R excel in all types of riding. Up front is a 43mm open-class version of Kawasaki’s highly acclaimed Big Piston Fork (BPF). Featuring a piston design nearly twice the size of a conventional cartridge fork’s, the BPF offers smooth action, less stiction, light weight and enhanced damping performance on both compression and rebound circuits. This compliance results in more control and better feedback – just what riders need when carving through a bumpy sweeper at the track or negotiating a decreasing-radius corner on their favorite backroad.
Rear suspension duties on the ZX-10R are handled by a Horizontal Back-Link design that positions the shock and linkage above the swingarm. Benefits include improved mass centralization, excellent road holding, compliance and stability, smooth action in the mid-stroke and good overall feedback. The fully adjustable shock features a piggyback reservoir and dual-range (low- and high-speed) compression damping.
Lightweight, gravity-cast three-spoke wheels complement the ZX-10R’s 17-inch radial supersport tires. Up front, Tokico radial-mount calipers squeeze 310mm petal rotors, while a lightweight single-piston caliper grabs a 220mm petal rotor in back. The result is powerful stopping with plenty of rider feedback and confidence.
At first, anti-lock braking might seem out of place on a purebred sportbike, but the ZX-10R ABS system was specifically designed to maximize performance on the street and track. As a result, the high-performance Kawasaki Intelligent anti-lock Brake System (KIBS) really is intelligent, as it utilizes a small and lightweight ABS unit designed by Bosch specifically with sportbikes in mind. The entire system only adds about 7 pounds of weight compared to the non-ABS equipped 2015 ZX-10R, with a full pound of that weight accounted for by the ABS model’s larger battery.
KIBS is a multi-sensing system that collects and monitors a wide range of information from wheel sensors (the same ones collecting data on the standard ZX-10R for its S-KTRC traction control system) and the bike’s ECU. This data set includes wheel speed, brake-caliper hydraulic pressure, engine rpm, throttle position, clutch actuation and gear position. The ABS ECU compares data continually with the 10R’s powertrain ECU. When the system determines a potential wheel lock-up situation is occurring, it tells the Bosch ABS unit to temporarily reduce brake-line hydraulic pressure for that wheel, allowing the wheel to regain traction. It all happens automatically and nearly instantaneously, in many cases interpreting and correcting traction loss before the rider is even aware of it.
Besides its ultra-quick response time, KIBS offers a number of additional sport-riding benefits, including rear-end lift suppression during hard braking, minimal lever kickback during ABS intervention, and increased rear-brake control during downshifts. Of great benefit to track riders, highly precise pressure control allows the system to maintain excellent braking performance and proper lever feel while also minimizing ABS pulses.
Öhlins Twin-Tube Steering Damper
Kawasaki developed the ZX-10R’s electronic steering damper in joint cooperation with Öhlins. Controlled by a dedicated ECU located under the gas-tank cover, this damper reacts to the rate of acceleration or deceleration, along with rear-wheel speed, to help provide the ideal damping-force level across a wide range of riding scenarios. Its variable damping capability provides optimum rider feedback by permitting softer damping for normal operation and firm damping for high-speed stability. The result is a light and nimble steering feel at low speed, and superior stability at higher speeds and during extreme acceleration or deceleration. The anodized damper unit incorporates Öhlins’ twin-tube design to help ensure stable damping performance and superior kickback absorption. It is mounted horizontally at the front of the fuel tank, requires very few additional components, and adds almost no weight compared to previous-generation steering dampers.
Bodywork, Lighting & Instrumentation
Kawasaki engineers wrapped the ZX-10R’s formidable technology in bodywork as advanced and stylish as anything this side of a World Superbike Championship grid. Curvy edges and contrasting colored and black parts create a sharp, aggressive image, while distinctive line-beam headlights permit using a more compact front fairing. LED turn signals integrate smoothly into the mirror assemblies, and convenient turn-signal couplers allow easy mirror removal for track days. The rear fender assembly holding the rear signal stalks and license plate frame is also designed to be easily removable for track use. High-visibility LED lamps are additionally used for the taillight and position marker.
Instrumentation is highlighted by an LED-backlit bar-graph tachometer set above a multi-function LCD display providing numerous sections and data panels. A wide range of information is available, including speed, odometer, dual trip meters, fuel consumption, Power Mode and S-KTRC level, low fuel warning, coolant temperature and much more. For track use, the LCD display can be set to “race” mode, which moves the gear-position function to the center of the display.
Rider Interface
The ZX-10R’s ergonomics are designed for an optimum blend of comfort and control. A realistic 32-inch seat height, adjustable footpegs and handlebars make the 10R a hard-core sportbike you can actually take on an extended sport ride, with reasonable comfort en route. Adding these creature comforts together with the ZX-10R’s formidable engine and running gear, its championship-grade electronics arsenal, and the unique appeal of an available 30th Anniversary model, means the 2015 ZX-10R ABS is not just a superb ride. It’s the ride of your life.
A complete line of Genuine Kawasaki Accessories, specifically designed and engineered for the Ninja ZX-10R motorcycle, is available through authorized Kawasaki dealers.
About Kawasaki
Kawasaki started full-scale production of motorcycles over a half century ago. The first Kawasaki motorcycle engine was designed based on technical know-how garnered from the development and production of aircraft engines, and our entry into the motorcycle industry was driven by Kawasaki's constant effort to develop new technologies. Numerous new Kawasaki models introduced over the years have helped shape the market, and in the process have created enduring legends based on their unique engineering, speed, power, design and riding pleasure. In the future, Kawasaki's commitment to maintaining and furthering these strengths will surely give birth to new legends.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, Side x Sides, and Jet Ski® watercraft through a network of almost 1,200 independent retailers, with close to an additional 7,400 retailers specializing in general purpose engines. KMC and its affiliates employ nearly 3,100 people in the United States, with approximately 300 of them located at KMC's Irvine, California headquarters.
Kawasaki’s tagline, “Let the good times roll.™”, is recognized worldwide. The Kawasaki brand is synonymous with powerful, stylish and category-leading vehicles. Information about Kawasaki’s complete line of powersports products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
2015 Kawasaki Ninja® ZX™-10R ABS
Features and Benefits
– Öhlins-Kawasaki electronic steering damper reacts to current speed as well as rate of acceleration and deceleration to vary the amount of damping force across a wide range of riding scenarios for ease of operation and optimal rider feedback
– Engine and chassis work together to allow for linear power delivery
– Sport-Kawasaki Traction Control (S-KTRC) continuously monitors wheel speed, throttle position, engine rpm and a host of other data to help ensure the optimal amount of traction without crossing over the razor’s edge of adhesion
– Advanced Kawasaki Intelligent Anti-lock Braking System monitors a wide range of data and enhances rider control
– Power Mode selector allows riders to select power level and power delivery to match riding conditions
– Aluminum frame has ideal strength and rigidity for maximum performance
– Big Piston Fork (BPF) helps maintain composure under braking and contributes to the fork’s light weight
– Horizontal back-link rear suspension helps deliver smooth suspension action with good road holding over a variety of pavement conditions
– Slipper-type back-torque limiting clutch helps prevent rear wheel hop under extreme deceleration and improves corner entry handling
– Race-oriented instrumentation offers riders a wealth of information at a glance
Öhlins-Kawasaki Electronic Steering Damper
– Specially tuned for the 2015 ZX-10R, this electronic damper helps provide the ideal amount of damping force across a wide range of riding scenarios
– Maintains a high level of rider feedback by allowing lower damping forces under less taxing conditions, but quickly adapts to increase damping and enhance high-speed stability when required
– Reacts to current speed as well as rate of acceleration or deceleration to help provide light steering feel at low speed, as well as superior damping at higher speeds or during extreme acceleration/deceleration
– Uses Öhlins’ patented twin-tube design to help ensure stable damping performance and superior kickback absorption
Liquid-cooled DOHC 998cc Inline-four Engine
– Design is compact, narrow and lightweight
– Camshafts, crankshaft and pistons designed to complement the engine’s prodigious power production
– Large intake valves, camshaft profiles and port shapes help maximize power production and smooth power delivery
– Chromoly camshafts enhance durability
– Single-shaft secondary balancer helps reduce vibration; its use allows several vibration-damping parts to be simplified and lightened
– Strong connecting rods suit the power potential of this engine
– ECU is small enough to be tucked away in a slot in the airbox assembly
– One-piece upper crankcase and cylinder casting offers maximum rigidity
– Low-friction oil pump reduces parasitic power loss
– A lightweight radiator with tightly packed cores provides efficient engine cooling
– A liquid-cooled aluminum oil cooler promotes high-efficiency heat dissipation
– Intake and exhaust valves are titanium to reduce reciprocating weight and stress at high rpm
Dual-injector Digital Fuel Injection
– Large 47mm throttle bodies help with throttle control
– Secondary fuel injectors enhance power output and power characteristics at high rpm; the lower injectors are always on, while upper injectors come on as needed according to degree of throttle opening and engine rpm
– Oval-shaped throttle bodies allow precise throttle control and instant response
– An Idle Speed Control (ISC) valve on the throttle body unit automatically adjusts idle speed, contributing to easier starts and off-idle throttle response
Sport-Kawasaki Traction Control – S-KTRC
– A highly sophisticated electronic system based on actual Kawasaki racing experience that’s designed to maximize forward motion by allowing racers to ride closer to the edge of traction
– The system crunches a wide range of data, including throttle position, wheel speed, engine rpm, wheel slippage and acceleration, with help from a speed sensor fitted to each wheel
– The quickest acceleration requires a certain amount of wheel slippage, so to optimize traction, S-KTRC actually allows for optimum wheelspin
– Using complex analysis, the system is able to predict when traction conditions are about to become unfavorable. By acting before slippage exceeds the range for optimal traction, the system can quickly and smoothly reduce power slightly so the wheel regains traction
– S-KTRC confirms conditions 200 times per second and governs ignition, which allows extremely quick response to changing conditions
– Riders can choose between three operational modes, depending on skill level and conditions
– A level meter on the LCD instrument panel displays how much electronic intervention the system is providing, in real time
Kawasaki Intelligent Anti-lock Braking System (KIBS)
– Advanced track-ready anti-lock braking system
– Utilizes a Bosch-built ABS unit that’s half the size of a standard unit and considerably lighter
– KIBS monitors a wide range of data, including front and rear wheel speed, throttle position, gear selection, engine rpm, caliper pressure, clutch actuation and more to help prevent wheel locking
– High-precision brake pressure control offers a number of sport riding benefits, including rear-end lift suppression, minimal kickback during operation and consistent lever feel
– ABS unit is located close to the bike’s center of mass, behind the left engine cylinder, which minimizes the effects of the added weight
– System uses wheel speed sensors already fitted to the non-ABS ZX-10R (used for S-KTRC traction control system)
– A radial-pump front master cylinder provides the ultimate in front brake feel and feedback
– Tokico radial-mount brake calipers use dual pads and offer a superb initial bite, progressive feel and a high degree of feedback to the rider
– A pair of 5.5mm thick, 310mm petal discs provides the heat dissipation needed to maintain brake feel and responsiveness during extended heavy use
– A 220mm rear petal disc gripped by a single-piston caliper provides excellent feel and feedback
Ram-air Intake
– A highly efficient and forward-positioned ram air intake is designed for low intake noise and good intake efficiency
– 9-liter airbox enhances breathing and power
– Oval-section intake funnels promote non-turbulent flow at all rpm
Titanium Exhaust System
– Titanium-header exhaust system with hydroformed header pipes and small, lightweight muffler assembly uses a pre-chamber that houses two catalyzers for emissions and sound reduction
– Headers have nearly identical specs to their roadracing counterparts, which makes it easier for riders to increase track performance with the simple addition of a less-restrictive muffler; now there’s no need to replace the lightweight and race-spec header assembly
– Dual catalyzers help the ZX-10R meet strict U.S. and Euro III exhaust emissions standards
Six-speed Transmission
– Race-style cassette transmission allows simple trackside gearing changes to suit individual circuits
– The “cassette” is located high enough that it can be accessed without having to drain engine oil
– Primary and final reduction ratios minimize rear end movement (squat/lift) during acceleration and deceleration
– Close-ratio 4th, 5th and 6th gears complement the ZX-10R’s circuit performance
– Overall gear ratios suit the power characteristics for ideal power delivery in all rpm ranges
– An adjustable back-torque limiting clutch facilitates smooth downshifts, a main contributor to stability under heavy braking
Chassis / Frame
– Aluminum-alloy frame offers optimal flex and rigidity characteristics for balanced handling on street or track
– Chassis geometry allows sharp steering characteristics and crisp handling with no corresponding tradeoff in chassis stability at speed
– Frame is an all-cast construction of only seven pieces, with ideal wall thicknesses that provide adequate strength and optimized rigidity
– Front end weight aids aggressive, on-the-gas corner exits
– Modifying or removing the exhaust pre-chamber (for racetrack applications only) enables two chain links to be removed, which offers riders the opportunity to alter chassis geometry by shortening the wheelbase by up to 16mm to suit different track layouts
– Like the frame, the alloy swingarm is an all-cast design, with just three pieces
– Narrow subframe layout contributes to the compact and slim tail section
Horizontal Back-link Rear Suspension
– Shock and linkage are positioned above the swingarm
– The design offers excellent road-holding, smooth suspension action, and stability and feedback when cornering
– The design positions the shock’s upper link to spread out the load and contribute to enhanced overall frame rigidity and improved mass centralization and chassis balance
– The fully adjustable shock features a piggyback reservoir and dual (high- and low-speed) compression damping, which enables fine tuning for racing or track-day use
– The Big Piston Fork (BPF) and Back-link suspension system contribute to rider control and faster lap times
– The Big Piston Fork’s (BPF) 43mm inner tubes is one of the contributing factors to the bike’s composure under braking
– Compared to a cartridge-type fork of the same size, the BPF features a 39.6mm main piston
– Oil inside the BPF acts on a surface area almost four times the size of a conventional fork’s. The larger surface area allows damping pressure to be reduced while helping to ensure that damping force remains the same
– Reducing damping pressure allows the inner fork tube to move more smoothly, which is especially noticeable at the initial part of the stroke. The result is greater control as the fork compresses and very calm attitude change as vehicle weight shifts forward under braking, and contributing to greater chassis stability on corner entry
– Because the BPF eliminates many of the internal components of a traditional cartridge fork, construction is simplified and overall fork weight is reduced
– Compression and rebound damping adjustments are located at the top of each fork tube, while preload is now at the bottom
Three-spoke Cast Aluminum Wheels
– Gravity-cast alloy wheels feature a three-spoke design
– Light wheels mean low unsprung weight, which allows the suspension system to work more efficiently
Ergonomics
– 32-inch seat height makes it easy to reach the ground
– Fuel tank shape offers a comfortable ergonomic fit with the rider’s forearms and inner thighs when riding
– Adjustable foot pegs can be lowered an additional 15mm when street riding or touring
Advanced Aerodynamic Bodywork
– Compact, curved shape
– Large ducting aids engine heat dissipation
– Line-beam headlights and short fairing contributes to the aggressive styling
– LED three-bulb position lamp at the top of the ram air duct offers enhanced visibility to drivers and pedestrians
– Fairing-mounted mirrors feature integrated, LED-type turn signals
– Turn signals are electrically connected via couplers, which allows easy mirror removal for track day riding
– Compact tail section includes an elegant, nine-bulb taillight
– Taillight and turn signal stalks are mounted on a rear fender assembly that’s easily removable for track day riding
Advanced Electronic Instrumentation
– Instruments feature a high-visibility bar-graph LED tachometer positioned above a multi-window LCD info panel that offers riders a massive quantity of information
– The tachometer also functions as a shift indicator: LEDs flash when the pre-set rpm is reached, and riders can set shift rpm according to preference
– The multi-function LCD features two display modes: Standard and Race. Switching to Race Mode alters the Speed display by changing it to Gear Position, and by changing the Clock display to Speed
– Additional functions include odometer, dual trip meters, average fuel consumption, instant fuel consumption, Power Mode (x3), S-KTRC (x4), S-KTRC level indicator, low fuel indicator, Economical Riding indicator (shows most favorable fuel consumption), water temperature and a host of indicator lamps
2015 Kawasaki Ninja® ZX™-10R ABS Specifications*
Displacement: 998cc
Bore x stroke: 76.0 x 55.0mm
Compression ratio: 13.0:1
Fuel system: DFI® with four 47mm Keihin throttle bodies with oval sub-throttles, two injectors per cylinder
Ignition: TCBI with digital advance and Sport-Kawasaki Traction Control (S-KTRC)
Rake / trail: 25.0 degrees / 4.2 in.
Rear tire: 190/55 ZR17
Wheelbase: 56.1 in.
Front suspension / wheel travel: 43mm inverted Big Piston Fork (BPF), adjustable stepless rebound and compression damping, spring preload adjustability / 4.7 in.
Rear suspension / wheel travel: Horizontal back-link with gas-charged shock, stepless, dual-range (low-/high-speed) compression damping, stepless rebound damping, fully adjustable spring preload / 5.5 in.
Front brakes: Kawasaki Intelligent anti-lock Braking (KIBS), dual semi-floating 310mm petal discs with dual four-piston radial-mount calipers
Rear brakes: KIBS-controlled, single 220mm petal disc with aluminum single-piston caliper
Overall length: 81.7 in.
Overall width: 28.1 in.
Overall height: 43.9 in.
Seat height: 32.0 in.
Curb weight: 443.2 lbs.
Fuel capacity: 4.5 gal.
Color choices: Metallic Matte Carbon Gray / Flat Ebony,
Lime Green / Pearl Stardust White
MSRP: $15,299 / $15,599 30th Anniversary Edition
*Specifications are subject to change.
2015 KAWASAKI NINJA® ZX™-6R ABS
New 30th Anniversary Model Celebrates Three Decades of Ninja Dominance
Thirty years ago, the Kawasaki 600 Ninja literally invented the 600cc supersport segment, which today remains one of the benchmark performance classes in the world. Now for 2015, Kawasaki celebrates three decades of racing wins and championships with a very special 30th Anniversary Ninja® ZX™-6R ABS, the ultimate expression of the Ninja’s “Forever Fearless” attitude in the middleweight sportbike class. Building on the current ZX-6R ABS platform, the 2015 edition features exclusive styling touches that uniquely identify it as the powerful descendent of the motorcycle that truly started it all.
What’s New For 2015
• A special 30th Anniversary Ninja® ZX™-6R ABS model features Lime Green/Pearl Stardust White paint, green pinstripe decals on the wheels, and 30th Anniversary badges on each side of the fairing
• The standard Ninja® ZX™-6R model is available in Metallic Matte Carbon Gray/Flat Ebony
Long-Stroke 636cc Engine
The 2015 Ninja ZX-6R story begins with the ultimate advantage over its 600-class competition – displacement. Offering 636cc vs. the 599cc of competing inline-four machines, the ZX-6R gives riders a significant 37cc increase in engine size resulting in much stronger low- and mid-range power, a premium asset for street riding, canyon carving and on-track authority. This performance advantage has been fully proven in the demanding arena of AMA Pro Road Racing, when the first revolutionary 636 blew away the competition’s 600s and won races against factory 750s on the track.
This category-shattering heritage, passed faithfully down through the ZX-6R’s most essential DNA, still resides in the latest model’s 16-valve, long-stroke DOHC 636cc inline-four. This engine provides the exact riding experience demanded by the most discerning
middleweight sportbike pilots. Torque rich and rev happy, the supremely powerful engine easily makes the transition from everyday city streets to the wide-open racetrack, making its broad spectrum of performance available to every rider. In fact, the ZX-6R powerplant is as happy breezing through the morning commute as it is tagging the rev limiter on the back straight, proving that the power capable of dominating on the track can also be smooth enough for everyday use.
The key to this immense bandwidth is the ZX-6R’s unique long-stroke engine design. Its additional 37cc of displacement compared to competing inline-fours makes a significant impact on real-world riding. Increased performance throughout the rpm range is always welcome for vigorous sport riding or racing, but it also significantly enhances everyday usability. Thanks to the ZX-6R engine’s larger displacement, low- through mid- range torque is significantly stronger and the engine’s total “area under the power curve” grows substantially when compared to traditional 600cc bikes.
Intake and exhaust port shapes are optimized to suit the displacement, helping to provide increased performance as well as improved throttle response. In particular, the intake ports are wider near the throttle bodies and split farther upstream from the valves, while the exhaust ports are wider near the valves and taper on their way to the exhaust header. The camshafts are made of lightweight chromoly steel, with greater intake duration and more intake and exhaust lift to complement the extra engine displacement. Meticulously finished piston crowns increase piston strength and accommodate the extra valve lift, while a molybdenum coating on the piston skirts fights friction and helps with engine break-in. Finally, the connecting rods are built to suit the kinetic energy of the long-stroke engine, and high-rigidity piston pins help ensure high-rpm durability.
The airbox has a large internal volume tuned to help the engine produce maximum power with a smooth power delivery. Inside are four single-bore intake funnels that contribute to low- and mid-range torque production, with different inner and outer funnel pairs that further enhance engine character. The Digital Fuel Injection (DFI®) system’s ultra-fine atomizing injectors deliver a sub-60 micron fuel droplet size for optimum air-fuel mixing and maximum combustion efficiency, while precise DFI mapping enhances throttle response and reduces emissions.
The end result is a 636cc engine that delivers class-leading drive out of corners, offers superior flexibility and precise throttle control. These virtues pay big dividends when making mid-corner power adjustments or stringing a set of curves together on a racetrack or twisting backroad.
F.C.C. Clutch & Cassette Gearbox
The ZX-6R’s heroic power is delivered through a high-tech F.C.C. clutch with assist and slipper functions. This advanced clutch design allows quick, effortless downshifts when scrubbing-off speed for a corner, while also helping minimize rear-wheel hop caused by excess back-torque. The design uses two types of cams, including an assist cam and a slipper cam, that were developed based on racetrack testing and expert rider feedback. The “assist” cam acts like a servo mechanism to pull the clutch hub and operating plate together, and compress the clutch plates under load. This allows the total clutch spring count and tension to be reduced, resulting in up to a 25% overall reduction in effort at the clutch lever. The assist cam also increases the clutch’s maximum torque capacity to help it cope with the 636cc engine’s extra power without adding to the overall component mass. Whenever back-torque is present, such as during rapid braking and downshifting, the clutch’s “slipper” cam reduces clamping force on the hub and operating plate to help prevent rear-wheel hop and allow for smooth corner entry. The spring plate assembly likewise offers smooth engagement and helps minimize vibration and clutch judder.
In keeping with its racing DNA, the ZX-6R also employs a cassette-type six-speed transmission to simplify gearing changes at the track, help reduce the time needed for bike setup and allow more time for riding. Strong alloys and idealized gear thickness provide optimum gearbox durability, making it the perfect match for the torquey 636cc engine.
Track-Ready Electronics
The Ninja ZX-6R features the most up-to-date sportbike and racetrack technology offered by Kawasaki. Its three-mode Kawasaki Traction Control (KTRC) system is similar to the KTRC unit found on the flagship Ninja ZX-14R, and features even more advanced programming than the S-KTRC system used on the ZX-10R superbike. And its selectable power modes offer numerous tuning options and maximum flexibility compared to the middleweight competition.
The KTRC traction control system on the Ninja ZX-6R combines the best elements of the S-KTRC and KTRC traction control systems on Kawasaki’s two flagship sportbikes. Three different KTRC modes are selectable via a switch on the left clip-on. Mode 1 offers maximum racetrack performance, Mode 2 offers sporty street performance, and Mode 3 virtually eliminates wheelspin and improves rider confidence on slippery surfaces. Riders may also turn the system completely off for total manual throttle control.
Just like the S-KTRC system on a ZX-10R superbike, the ZX-6R’s KTRC Mode 1 and Mode 2 prioritize maximum forward acceleration. To do so, sophisticated computer algorithms predict when available traction is about to be compromised, and then initiate KTRC intervention before slippage exceeds the optimum acceleration range. This minimizes how much power must be reduced to improve or restore rear-wheel traction, while also helping to provide maximum forward drive. Operating parameters are monitored and confirmed 200 times per second, with the system using only ignition timing to regulate the engine’s power output, allowing extremely quick response. KTRC Mode 3 features similar tuning to a Concours® 14 ABS sport tourer’s traction control system. During normal operation, Mode 3 uses the same logic and control method as Mode 1 and Mode 2, but immediately switches to three-way intervention – using ignition timing, fuel delivery and the intake tract’s sub-throttles – if excessive rear-wheel spin is detected. This allows Mode 3 to reduce engine output down to a level that will allow the rear wheel to regain grip, even on very slippery surfaces.
The fine control provided by the dual throttle valves also results in a very natural throttle feel and smooth transitions no matter how quickly the rider opens the throttle. This highly effective system uses minimal hardware paired with very advanced software programming that monitors various parameters and rider inputs. The only additional hardware required by the KTRC system is a set of front and rear wheel-speed sensors so it can calculate rear-wheel slippage. In sum, the overall effects of Modes 1, 2 and 3 are easy to distinguish from each other and effectively cover a wide range of riding conditions.
Riders can select either “Full” or “Low” engine power modes via a switch on the left clip-on. The power modes allow quick adjustment the power delivery to help suit road or track conditions, or personal preference. Full mode unleashes the engine’s full performance potential. Low mode offers the same low-rpm power output, but begins to limit power as the rpm rises into the midrange and then offers only 80% of the engine’s maximum power. Low mode also delivers a softer throttle response, a handy feature when the rider wants to relax.
Combining the KTRC and Power Mode options, riders have a total of eight combinations from which to choose, and each system can be independently set to match rider skill/preference, riding location and surface conditions. An experienced rider on dry pavement might choose “Full Power” and “KTRC Mode 1” for a trackday or club race, but in wet and/or slippery conditions, that same rider might choose “Low Power” and “KTRC Mode 3.” As noted above, the various modes are easily selectable from a convenient switch on the left clip-on.
High-Performance ABS Brake System
Impressive engine and traction-control electronics are complemented by the Kawasaki Intelligent anti-lock Brake System (KIBS) on the 2015 Ninja ZX-6R ABS. The “intelligent” term is truly appropriate, considering just how smart KIBS is. It all starts with a compact and ultra-lightweight Bosch ABS control unit designed specifically for sportbikes. KIBS is a multi-sensing system that collects and monitors a wide range of data from wheel speed sensors (the same ones collecting info for the KTRC traction control system) and the bike’s engine control unit (ECU). Monitored parameters include wheel speed, brake caliper pressure, engine rpm, throttle position, clutch actuation, and current gear selection. The KIBS ABS ECU communicates with the engine’s ECU and crunches the numbers, and when it senses a potential lock-up situation, it signals the ABS unit to temporarily reduce brake-line pressure, helping the wheel to regain traction. Aside from an ultra-quick response time, additional sport-riding benefits include rear-end lift suppression during hard braking, reduced brake-lever kickback during ABS activation, and enhanced rear brake control during downshifts. Unlike in some less advanced systems, Kawasaki’s high-precision pressure control unit helps maintain brake-system performance and proper lever feel during ABS activation.
One-piece Nissin “monobloc” radial-mount brake calipers are highly rigid, offer excellent heat dissipation, and are 45 grams lighter than a comparable two-piece caliper. The monobloc calipers are paired with 310mm petal-type front rotors to help provide superb braking power, with great feel at the lever. Adopted from the ZX-10R superbike, the rear brake caliper helps offer good fade-resistance and optimum rear brake performance in conjunction with a 220mm petal-type rotor. The rear master cylinder reservoir mounts forward of the swingarm pivot to maximize free space around the footpeg. In addition, the rear brake pedal is coaxially mounted with the footpeg for excellent mid-stroke braking efficiency and optimum feel.
Suspension & Chassis
The Showa Separate Function Fork–Big Piston (SFF-BP) combines the innovative concepts of an SFF and a BPF to deliver next-generation suspension performance. The fork utilizes springs on both sides, with adjustable spring preload in the left tube and adjustable Big Piston compression and rebound damping in the right tube. All adjusters are located on the upper fork caps for convenient access. Smooth initial stroke action and excellent composure under braking are decisive BP strengths. True to its “Big Piston” name, the large-diameter damping piston in the right fork leg is much bigger than the dampers used in traditional “cartridge” forks with the same external dimensions. Since oil inside a BP fork leg acts against a much larger surface area, the damping pressure can be reduced without compromising the overall damping effectiveness. Reducing the damping pressure also allows the inner fork tube to move more smoothly, which is especially noticeable during the initial part of the stroke. The result is greater composure as the fork begins to compress, and a less severe change in chassis attitude (reduced dive) during hard braking. The SFF-BP is primarily tuned for use on twisty roads, with the tuning also allowing a high level of performance at the racetrack, and comfortable response in the city and on the highway.
Kawasaki’s patented bottom-link Uni-Trak® rear suspension offers 5.3 inches of travel and features a gas-charged shock with adjustability for spring preload, 25-position rebound damping and stepless compression damping. Linkage and lever ratios deliver impressive ride quality in both city and highway conditions.
Lightweight twin-spar aluminum frame engineering places the engine in the optimum position for superb handling and rider feedback. It features a 23.5-degree rake angle that helps quicken steering response, enhance maneuverability and promote clear communication to the rider from the front tire. It also uses low friction steering-stem seals for more precise steering inputs and lighter handling at low speeds.
Bodywork & Ergonomics
The 2015 ZX-6R bodywork features highly aggressive design elements for a characteristic and unique Ninja appearance. Large fairing openings provide increased airflow and enhanced heat dissipation, while the fairing lowers, rear cowl and assorted blacked-out body panels contribute to the bike’s compact and lightweight appearance. Projector-beam headlights are encased in a sharp-edged housing that features integrated position lamps, and a sleek one-piece front fender adds to the excellent aerodynamics. Semi-flush front turn signals are built into the bodywork, and compact rear turn signals complement the minimalist tail section. The ZX-6R’s compact LED taillight is lightweight, very bright and offers a modern high-tech appearance. And finally, a “hugger” fender above the swingarm helps reduce aerodynamic turbulence and keep the undertail area clean.
A critical feature for sportbikes, the ZX-6R’s seat, footpeg and handlebar relationship places the handlebars close to the rider and at an angle that promotes a highly intuitive and comfortable riding position. The fuel tank is flared around its top edge to provide a large leg and knee contact area, further contributing to the excellent chassis feedback. Together with a narrow lightweight aluminum rear sub-frame, the seat’s leading edge provides a slender and effective high-performance sportbike riding position, as well as a shorter reach to the pavement. This helps the Ninja appeal to an even wider range of riders.
Multi-Function Instrumentation Display
The crisp LCD instrument panel gives at-a-glance information to the rider, including an analog-style tachometer and a multi-function screen to enable the rider to select the combination of information displayed prominently. Primary functions on the LCD panel include KTRC, Power Mode and Economical Riding (ECO) indicators. Additional functions include a digital speedometer, odometer, dual trip meters, clock, instant and average fuel consumption, coolant temperature, as well as a shift indicator, traction control activity level, ABS indicator and low-fuel warning lights. A large gear-position indicator gives instant numerical gear confirmation. The mirror design offers increased rearward visibility without increasing overall vehicle width.
A complete line of Genuine Kawasaki Accessories, specifically designed and engineered for the Ninja ZX-6R motorcycle, is available through authorized Kawasaki dealers.
2015 Kawasaki Ninja® ZX™-6R ABS
– Class-leading Supersport performance and styling delivers an abundant dose of street potency
– 636cc inline-four offers racetrack-ready power yet extremely flexible delivery on the street
– Selectable engine power modes allow riders to adjust power delivery to riding conditions
– Three-mode KTRC traction control puts the power to the pavement whether it’s dry and grippy or rain-slick
– Showa Separate Function Fork - Big Piston (SFF-BP) offers light weight, easy adjustability and smoother initial suspension tracking
– Supersport-grade KIBS ABS provides maximum stopping performance, with added peace of mind
– Nissin one-piece “monobloc” radial-mount front brake calipers and radial-pump front brake master cylinder offer superb braking modulation with a direct feel at the lever
– F.C.C. clutch with assist function offers light clutch pull and strong clamping force for less clutch slippage under acceleration while slipper function minimizes wheel chatter caused by aggressive downshifting
– Aggressive styling and sharp, aerodynamic bodywork clearly shouts: “Performance Counts!”
– Lightweight twin-spar aluminum frame places the engine in the optimum position for superb handling and rider feedback and also features a 23.5-degree rake angle for quick steering response, maximum maneuverability and to deliver clear communication from the front tire
– Reduced friction steering stem seals for easy steering inputs and noticeably improved low speed handling
636cc Engine
– 636cc displacement uses a long stroke to boost engine performance throughout the rev range. Low-mid range torque is especially impressive, and provides satisfying real world performance
– Digital Fuel Injection (DFI®) system features four 38mm Keihin throttle bodies with oval sub-throttles and dual throttle valves for smooth response and maximum power
– Chromoly steel camshafts are light, strong and durable
– Piston crown enhances strength and accommodates the high valve lift
– 12.9:1 compression ratio is optimum for this engine’s bore & stroke
– Molybdenum coating on piston skirts reduces friction and facilitates engine break-in
– Strong connecting rods suit the power delivery of this engine
– High-performance airbox design contributes to peak power and smooth power delivery
– Single-bore intake funnels improve low-mid range torque. Two different funnel shapes (outer are the same, inner are the same ) help deliver optimized throttle response
– Ultra-fine atomizing injectors help ensure complete air-fuel mixing and maximum combustion efficiency. Optimum tuning contributes to reduced emissions
– Balance tubes on all four header pipes to maximize low-end torque
– Exhaust pre-chamber makes efficient use of space, reduces exhaust noise and allows a smaller muffler to be used
– Triangular cross-section muffler provides sufficient internal volume while still offering good ground clearance and maximum lean angle, as well as a compact appearance
– Generator designed to produce less heat and reduce mechanical loss
– Zero-cross control voltage regulator significantly reduces the amount of electronic noise produced when it interrupts the generator’s output
– Cassette-type transmission helps simplify ratio-swaps and reduce set-up time at the track
– Lightweight EK 520 RMX/3D x-ring drive chain is very compact and uses lightening holes on the inner link plates to reduce weight.
Selectable Power Modes
– Power mode selector on the left clip-on gives ZX-6R riders the option to choose between “Full” and “Low” engine power delivery modes to suit their needs
– Output at low rpm is the same in both modes, but “Low” mode limits peak engine output to approximately 80% and gives a softer throttle response. “Full” mode allows the full performance potential of the engine to be unleashed
Three-Mode Kawasaki Traction Control (KTRC)
– Three-mode KTRC traction control combines the best high tech elements of the Ninja ZX-10R S-KTRC and ZX-14R/Concours® 14 KTRC systems.
– Three different modes are tuned to cover a wide-range of situations from advanced racetrack use, to normal street riding, to mixed/slippery conditions, for enhanced rider confidence
– Mode 1 is tuned to allow a degree of wheel slip to achieve maximize acceleration, like the ZX-10R S-KTRC system
– Mode 2 is tuned to help provide a balance of performance with minimal wheel slip
– Mode 3 prioritizes slip elimination, similar to the Concours14 ABS sport touring KTRC system, for enhanced rider confidence in mixed or slippery conditions
– The KTRC system may also be turned-off completely, at the rider’s discretion
– Handy mode selector on the left clip-on makes it easy for the rider to change KTRC settings
– Using complex programming algorithms, the KTRC system is able to predict impending wheelspin and act before slippage exceeds the optimum range, allowing reductions in power to be minimized for ultra-smooth operation
– In modes 1 and 2, conditions are analyzed 200 times per second and any necessary adjustments are made through ignition timing alone, for extremely quick response from the engine and KTRC system
– In Mode 3, the system functions like mode 2 under most conditions, but when excessive rear wheel spin is detected, Mode 3 switches to complete three-way control of ignition timing, fuel delivery and intake airflow to regulate engine output to a level that allows the rear wheel to regain grip. By controlling the sub-throttles in the intake tract for precise torque management, a smooth and natural feeling can be attained: Mode 3 intervention and on/off transitions are very smooth to help maintain stability
– The system uses minimal hardware supplemented by advanced software. In addition to the engine’s ECU, the system only requires front and rear wheel speed sensors, meaning minimal additional weight is required for traction control.
F.C.C. Clutch with Assist and Slipper Functions
– F.C.C. clutch with assist & slipper functions uses two types of cams, an assist cam and a slipper cam that were developed based on racetrack testing and rider feedback
– The F.C.C. clutch’s “assist” cam acts like a self-servo mechanism, pulling the clutch hub and operating plate together to compress the clutch plates under load. This allows the total clutch spring count and pressure to be reduced, resulting in up to a 25% reduction in effort at the clutch lever
– The assist cam also increases the torque capacity of the clutch so it can cope with the extra torque produced by the 636cc engine, without gaining any weight
– The F.C.C. clutch’s “slipper” cam reduces the clamping force on the clutch hub and operating plate when back-torque conditions are present and helps prevent rear wheel hop on trailing-throttle and when down-shifting
– Spring plate assembly provides smoother engagement and helps minimize clutch judder
Supersport-grade KIBS ABS with Monobloc Nissin Calipers
– KIBS is a multi-sensing system, using input from numerous sources. In addition to front and rear wheel speed sensors (standard for any ABS system), KIBS also monitors front caliper hydraulic pressure and data from the engine’s ECU (throttle position, engine speed, clutch actuation and gear position)
– Compact, lightweight BOSCH ABS unit was designed specifically for sportbike use and made its first mass-production appearance on the 2011 Ninja ZX-10R
– Highly-precise brake pressure control enables the system to avoid a reduction in brake performance due to excessive pressure drops, and allows good brake lever feel to be maintained during KIBS intervention by providing smaller and lighter ABS pulses than comparable systems
– Supersport models frequently encounter higher braking forces than less sporting models, so there is a greater likelihood of rear tire lift under extreme deceleration. By monitoring hydraulic pressure at the front calipers, KIBS is able to regulate pressure increases and help reduce the tendency of the rear tire to lift.
– By accounting for back-torque, KIBS is able to offer increased rear brake control during downshifts. KIBS parameters include throttle position, clutch actuation and gear position, allowing the system to predict back-torque caused by trailing-throttle at high-rpm, or down-shifting. Rear wheel slip due to engine braking often triggers ABS action on standard systems, but by preventing unnecessary ABS intervention in these situations, KIBS helps enhance rear brake control
– Thanks to the compact size and light weight of the ABS unit, the entire system adds only 4.4 pounds compared to non-ABS models
– Highly rigid, radial-mount “monobloc” Nissin brake calipers offer superb control and a firm feel at the front brake lever
– Semi-floating 310mm stainless-steel petal-type front rotors contribute to strong braking performance
– Radial-pump master cylinder gives excellent lever feel and helps offer superb brake modulation
– Front brake hose routing features a three-way joint at the lower triple clamp that facilitates effective brake line bleeding to help maintain a firm feel at the front brake lever
– ZX-10R superbike rear brake caliper helps offer good anti-fade performance and squeezes a 220mm petal-type rotor
– Rear brake pedal is mounted coaxially with the footpeg for good braking efficiency mid-stroke and excellent response to lever inputs
– Rear brake master cylinder reservoir is mounted forward of the swingarm pivot, to maximize space around the footpeg
Separate Function Fork – Big Piston: (SFF-BP)
– SFF-BP fork combines the features of Showa’s big piston and separate function forks, featuring springs on both sides, with dedicated preload adjustability in the left tube and dedicated damping pistons and adjustability in the right tube
– Big Piston design provides smooth action during the initial part of the stroke and contributes to excellent feel during heavy braking. The large-diameter damper piston is much bigger than those used in traditional “cartridge” forks
– Big Piston design allows the fork oil to act on a much larger surface area, so the damping pressure can be reduced without compromising effectiveness. Reducing the damping pressure allows the slider to react more smoothly, which is especially noticeable during the initial part of the stroke. The result is greater control as the fork begins to compress and very calm response during braking-induced weight-transfer, for greater chassis stability on corner entry
– Fork settings were tuned for maximum effectiveness on twisty roads, allowing a high level of performance for the racetrack, with a comfortable ride in the city and on the highway
– SFF-BP design offers much easier adjustability, by locating all adjusters in the caps at the top of the two fork tubes: preload on the left; compression and rebound damping on the right.
Bottom-link Uni-Trak® Rear suspension
– Bottom-link Uni-Trak® rear suspension offers 5.3 inches of travel and features a gas-charged shock
– Rear spring features a softer rate to enhance ride comfort and compliance when the road isn’t racetrack-smooth
– Rear suspension linkage has a high leverage ratio for improved rear ride comfort
– Full adjustability includes: stepless compression and rebound damping adjustments and fully adjustable spring preload. The top of the shock is also threaded and captured between nuts to allow for adjustable ride height
Lightweight Chassis
– A 23.5 degree rake angle helps quicken steering response, enhance maneuverability and delivers clear communication from the front tire
– Low friction steering stem seals for easy steering inputs and light low speed handling
– Intake resonator box and supports for the instrument panel and mirrors are unitized with the ram air duct, contributing to weight savings and increased rigidity
– Forward-tilted engine layout gives a steep intake angle and excellent center of gravity
– The sub-frame is a lightweight two-piece aluminum die-casting and is very narrow for a compact and slim rear profile
Bodywork
– Front fairing features a sharp design that communicates an aggressive image
– Large fairing openings provide increased airflow and enhanced heat dissipation
– Lower fairing, rear cowl, and assorted blacked-out panels contribute to the bike’s compact and lightweight appearance
– One-piece front fender offers excellent aerodynamics
– Projector beam headlights feature sharp looking housings with integrated position lamps
– Front turn signals are built into the bodywork and compact rear turn signals complement the minimalist tail section
– Compact LED taillight is lightweight, very bright and offers modern high-tech appearance
– Inner fender above the swingarm helps to reduce turbulence and helps keep the undertail clean
Cockpit
– Instrument panel gives at-a-glance information to the rider. An analog-style tachometer is complemented by a multi-function LCD screen
– LCD functions include KTRC, Power Mode and Economical Riding (ECO) indicators
– Additional LCD functions include a digital speedometer, odometer, dual trip meter, clock, instant and average fuel consumption, coolant temperature, and shift indicator, traction control activity and low-fuel warning lamps
– Large gear position indicator gives instant numerical gear confirmation
– Mirror design offers increased rearward visibility without increasing overall vehicle width
– Ergonomic seat-peg-bar layout places the handlebars close to the rider and the footpegs in a moderate rearset position for an intuitive high-performance riding position that is comfortable enough for everyday use
– Fuel tank is flared around its top, similar to the ZX-10R, providing a large contact patch for transmitting excellent feedback to the rider
– Slim-waisted fuel tank makes it easy for the rider to grip the tank with their knees, or to hang off in turns
– Front of seat is narrow and low for a slim riding position and a short reach to the pavement
– An adjustable Öhlins twin-tube steering damper is available as an accessory, to help ensure stable damping performance and superb kickback absorption, even under race conditions.
– A taller, “bubble” windscreen is available to provide enhanced aerodynamic protection
– Frame sliders/engine guards are available to help protect the engine and chassis
– Axle sliders are available to help protect the fork legs and front brakes
– A stylish color-matched seat cowl is available and mounts in place of the rear seat to enhance the visual aggression of the Ninja ZX-6R
2015 Kawasaki Ninja® ZX™-6R ABS Specifications*
Displacement: 636cc
Bore x stroke: 67.0 x 45.1mm
Compression ratio: 12.9:1
Fuel injection: DFI® with four 38mm Keihin throttle bodies and oval sub-throttles
Final drive: 520 series sealed chain
Rake / trail: 23.5 degrees / 4.0 in.
Frame type: Aluminum perimeter
Rear tire: 180/55 ZR17
Wheelbase: 54.9 in.
Front suspension / wheel travel: 41mm inverted Showa SFF-BP fork with top-out springs, stepless compression and rebound damping, adjustable spring preload / 4.7 in.
Rear suspension / wheel travel: Bottom-link Uni-Trak® with gas-charged shock, stepless compression damping adjustment, 25-way adjustable rebound damping, fully adjustable spring preload / 5.3 in.
Front brakes: Dual 310mm petal rotors with dual radial-mount, Nissin four-piston, monobloc calipers and KIBS ABS
Rear brake: Single 220mm petal rotor with single-piston caliper and KIBS ABS
Overall length: 82.1 in.
Overall width: 27.8 in.
Seat height: 32.7 in.
Curb weight: 428 lbs.
Color choices: Pearl Crystal White / Flat Ebony,
MSRP: $12,699 / $12,999 30th Anniversary Edition
Kawasaki Protection Plus: 12, 24, 36 or 48 months
