Honda Gives Us a New LIghtweight Naked Bike for 2015
Light, naked, and easy on the wallet: Honda gives us everything we like. Honda has revealed a new single cylinder naked bike for 2015 coming in at four grand. It isn't bad looking either. But can Honda deliver their trademark quality standards at such a low price? If so, it could make for a fantastic commuter.
Honda says:
This light and nimble-handling naked bike offers plenty of fun for motorcyclists—experienced riders and those new to the sport. Featuring a 300-class engine, the new CB300F carries a dash of attitude along with its versatile creds. Whether you’re commuting, zipping around town or headed out for a weekend ride, its roomy ergonomics, great handling and broad powerband make every ride a blast. Thanks to its affordable price tag, adding on a few Honda accessories is easy—a simple way to give it that extra bit of flair and make it uniquely your own. For example, a lower and narrower seat can be selected to create an easier reach to the ground for those with a shorter inseam. Price: $3999; Availability: Fall
- Engine displaces 286cc for responsive power throughout the rev range.
- Derived from the CBR250R engine, a new crankshaft and connecting rod create a longer engine stroke (up to 63mm from 55mm) to add 37cc of displacement.
- PGM-FI fuel injection produces crisp throttle response throughout the rev range.
- Stylish CBR500R-inspired exhaust system features larger internal volume for increased performance, enhanced appearance and a throaty exhaust note.
- Specially configured seat and side covers provide an easy reach to the ground.
- Full LCD multi-function digital meter.
- Affordable pricing: $3999.
- Transferable one-year, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
Honda Genuine Accessories†
Honda Racing Seat Bag, Carbon Fiber Tank Pad, Carbon Fiber Fuel Lid Cover, Drive Chain Case (Carbon-Style), Under Engine Cowl (Carbon-Style), Front Fender (Carbon-Style), Under Cowl (Carbon-Style), Front Headlight Cover (Carbon-Style), Tank Shroud (Carbon-Style), Chrome Bar Ends, Seat Cowl (Color-matched), Honda Racing Red Reflective Wheel Stripe Stickers
Honda Signature Accessories†
Available Accessory Seat is more than 1 inch lower than standard seat for easier reach to the ground.
† WARRANTY: Because we're so confident in the quality of each of our Honda Genuine Accessories, we're pleased to offer one of the best warranties in the industry. One-year warranty begins on the day accessories are purchased by the customer.
Engine Type: 286cc liquid-cooled single-cylinder four-stroke
Bore and Stroke: 76.0mm x 63.0mm
Compression ratio: 10.7:1
Valve Train: DOHC; four valves per cylinder
Induction: PGM-FI, 38mm throttle body
Ignition: Computer-controlled digital transistor with electronic advance
Final Drive: O-ring-sealed chain
Suspension Front: 37mm fork; 4.65 inches travel
Rear: Pro-Link® single shock with five-position spring preload adjustability; 4.07 inches travel
Brakes Front: Twin-piston caliper with single 296mm disc
Rear: Single-caliper 220mm disc
Tires Front: 110/70-17 radial
Rear: 140/70-17 radial
Wheelbase: 54.3 inches
Rake (Caster angle): 25° 30’
Trail: 98mm (3.9 inches)
Seat Height: 30.7 inches
Fuel Capacity: 3.4 gallons
Estimated Fuel Economy**: 71 MPG
Color: Red
Curb Weight*: 348 pounds
*Includes all standard equipment, required fluids and full tank of fuel—ready to ride.
**Miles per gallon values are calculated estimates of fuel consumed during laboratory exhaust emissions tests specified by the EPA, not during on-road riding. Use for comparison purposes only. Your actual mileage will vary depending on how you ride and maintain your vehicle, weather, road conditions, tire pressure, cargo and accessories, rider and passenger weight, and other factors.
Meets current CARB and EPA standards.
Models sold in California meet current CARB standardsand may differ slightly due to emissions equipment.
Tags: 2015, new models, honda
