BIKELAND > FORUMS > ZX-14.com > Thread: DynoJet Electric shifter NEW TOPIC NEW POLL POST REPLY
Vegasdude
posted June 20, 2006 11:56 AM
I read somewhere someone installed a DynoJet electric shifter that hooks into the PC3. I know you have to make a bracket to fit it to our shifters. I was wondering if anyone has any pics and advice on this mod...................Thanks.
posted June 20, 2006 12:02 PM
http://www.powercommander.com/quickshift.shtml
GUNNER
posted June 20, 2006 12:12 PM
It's a switch that splices into the shifter rod.
posted June 20, 2006 12:24 PM
There is no shifter rod on the 14!
A small bracket could be fabbed to the rear motor mount above the swingarm pivot, or off the front side of the main frame spar.
Since it is a extruded cast, a small hole could be drilled and the top of the sensor mounted there.
I was looking at that, but have not decided If I will go air shifter or not.
Gunner
posted June 20, 2006 12:34 PM
Damnit MAN!! You're right!!!!!
Well anyway that's how it works on 99% of the shit out there.
magzx12r
posted June 20, 2006 12:49 PM
You can get the quick shifter button instead of the quick shifter rod. They both cut fuel for a specified amount of time. I have it set for 55 or 60 ms on my ZX-10R. You preload your shifter just before you hit the button to shift. It shifts into the next gear without rolling off the throttle or pulling in the clutch.
Part # 4-105 (Handlebar Switch)
Mark
'03 ZX-12R
'12 1199S
MasterBlaster
posted June 20, 2006 02:19 PM
I helped my Bud install a solonoid shifter on his Busa. It kills at the coils when you hit the button. It also hooks to the shifter directly. Nice system, doesnt need air and is very quick. I will see if I can find out what brand it is. Was simple install and set up, and has been working great for over a year. ...TB
iflyphi
posted June 20, 2006 03:08 PM
How bout just a plain old airshifter??? Muzzy is making a Co2 shifter for the ZX14. It bolts on, no fabrication necessary. It has "Digi-kill" which interupts the fuel momentarily before the rod activates to shift the bike. You can fill the high pressure tank with nitrogen or C02 and get about 800 shifts.
Ok Rob Muzzy, how bout giving 20% off for the advert????
posted June 20, 2006 03:09 PM
doubt that'll happen... we just sent him a bill
iflyphi
posted June 20, 2006 03:12 PM
Thanks fish, I knew I could count on you. Go Ivan!!!!! Oooopsss, wrong thread. I'm sucha assh0le
posted June 20, 2006 03:28 PM
My RoadRacing buddies swear by the quick shifter...
You have to have a power commander to use the quick shifter, thats why I wont install it...No USB PC for me, never!!!
posted June 20, 2006 04:54 PM
Unless I read wrong, the quick shifter IS pc3 usb compatable! ?
TJ
posted June 20, 2006 05:24 PM        Edited By: TJ on 20 Jun 2006 18:31
It does work the the PC3 USB but the PC is not required. Here is a Cycleworld write-up...
http://www.cycleworld.com/article.asp?section_id=16&article_id=46
vegasdude
posted June 20, 2006 09:21 PM
TJ, is that your bike in the pic? If so what did you use to anchor the dynojet shifter? Tell me more!! Thanks............
vegasdude
posted June 20, 2006 09:23 PM
I'm going to talk to Dusty on Saturday about the button too........! Thanks..........
TJ
posted June 20, 2006 10:03 PM
Not my bike. I just thought the picture would give guys an idea of how the shifter works on a bike without linkage. I plan on getting the DJ quickshift unit once my ZX14 PC3 comes in.
tslewisz
posted June 21, 2006 05:39 AM
I have one.
zxlnt
posted July 22, 2006 01:06 AM
Does the shifter as shown above need to have the expansion module to work, or does it plug directly into the PC USB??
posted July 22, 2006 05:22 AM
It plugs into the PC3
zxlnt
posted July 22, 2006 09:54 AM
Hmm that probably means the quickshifter button plugs into the PC as well. Just preload the shifter and push the button. I see my next purchase happening soon...
iflyphi
posted July 22, 2006 10:30 AM
Now why doesn't somebody figure out a way to harness the PCIII to work with a regular airshifter?? You could set it up kill the fuel momentarily to shift when you hit the button, or even set it to shift at a certain rpm automatically.
posted July 22, 2006 07:07 PM
Hey, if you are gonna want pushbutton shifting on the street, Yamaha has a bike for you.
Copyright 2000-2025 Bikeland Media
0.21816086769104 seconds processing time
